HTTPS error
Aug 29th, 2008
Hi, when i try loggin by HTTPS on a router i have next errors.
%HTTPS: http ssl get context fail (-41104)
HTTP: ssl get context failed (-40407)
I have a 2821 router with
c2800nm-advipservicesk9-mz.124-15.T1.bin ios
Can anybody help me?
garytayl Mon, 09/01/2008 - 05:26
  • Silver, 250 points or more
Try the following:
Router(config)#crypto key zeroize rsa
Router(config)#crypto key generate rsa
How many bits in the modulus [512]: 1024
% Generating 1024 bit RSA keys ...[OK]
garytayl Mon, 09/01/2008 - 05:47
If you have ip http secure-client-auth in your config, try removing it and then https again.
johnlloyd_13 Mon, 09/01/2008 - 12:07
  • Blue, 1500 points or more
try to add these on your router:
Router(config)#username privilege 15 password <0 or 7>
Router(config)#ip http authentication local
Router(config)#line vty 0 4
Router(config-line)#login local
Router(config-line)#transport input ssh
privilege 15 allows you to configure your router. also, check if you IOS supports crypto functionality
johnlloyd_13 Mon, 09/01/2008 - 12:09
i forgot to add this:
Router(config)#ip http secure-server
this command enables https access on the router
A.Timoshenko Mon, 09/01/2008 - 23:20
ssh 1.5 work correct.
of course i know about "ip http secure-server" command.
eng.malak Sat, 10/20/2012 - 14:25
i know this is very old topic but any lick to solve it ?
locbus123 Mon, 12/03/2012 - 13:29
hi,
the solution is easy and gave it above:
you have to generate key but 1024 not 512 this one is to SSH1.5.... i checked it a few minutes ago
matthias.motte Wed, 01/11/2017 - 01:51
To fix it I do the folowing :
(conf)#crypto key zeroize rsa
(conf)#ip http secure-server
Try again my connexion to ssl server and ... it's work like a charm ;)
After I create a new rsa key (1024)
(conf)#crypto key generate rsa modul 1024
Try ssh and https, work together now ;)
