08-30-2008 09:39 AM - edited 03-06-2019 01:05 AM
We use a Cisco 2610XM router and would like to eliminate the buffer failures in the public buffer pool. Can anyone help me out how to fine tune this?
Buffer elements:
997 in free list (500 max allowed)
257569601 hits, 0 misses, 500 created
Public buffer pools:
Small buffers, 104 bytes (total 50, permanent 50, peak 83 @ 2d04h):
45 in free list (20 min, 150 max allowed)
47060333 hits, 89 misses, 137 trims, 137 created
0 failures (0 no memory)
Middle buffers, 600 bytes (total 25, permanent 25, peak 78 @ 2d04h):
22 in free list (10 min, 150 max allowed)
13317461 hits, 613 misses, 107 trims, 107 created
83 failures (0 no memory)
Big buffers, 1536 bytes (total 50, permanent 50, peak 76 @ 2d04h):
49 in free list (5 min, 150 max allowed)
17448540 hits, 8217 misses, 26 trims, 26 created
7972 failures (0 no memory)
VeryBig buffers, 4520 bytes (total 10, permanent 10, peak 12 @ 2d04h):
10 in free list (0 min, 20 max allowed)
48 hits, 7924 misses, 2 trims, 2 created
7924 failures (0 no memory)
Large buffers, 5024 bytes (total 1, permanent 0, peak 4 @ 2d04h):
1 in free list (0 min, 10 max allowed)
6 hits, 7918 misses, 22 trims, 23 created
7918 failures (0 no memory)
Huge buffers, 18024 bytes (total 1, permanent 0, peak 2 @ 2d04h):
1 in free list (0 min, 4 max allowed)
4 hits, 7914 misses, 20 trims, 21 created
7914 failures (0 no memory)
Interface buffer pools:
CD2430 I/O buffers, 1536 bytes (total 0, permanent 0):
0 in free list (0 min, 0 max allowed)
0 hits, 0 fallbacks
Header pools:
Header buffers, 0 bytes (total 510, permanent 128, peak 510 @ 7w0d):
382 in free list (10 min, 512 max allowed)
4367 hits, 247 misses, 0 trims, 382 created
9 failures (0 no memory)
128 max cache size, 128 in cache
54534511 hits in cache, 4251 misses in cache
Particle Clones:
1024 clones, 0 hits, 0 misses
Public particle pools:
F/S buffers, 256 bytes (total 384, permanent 384):
128 in free list (128 min, 1024 max allowed)
256 hits, 0 misses, 0 trims, 0 created
256 max cache size, 256 in cache
0 hits in cache, 0 misses in cache
Normal buffers, 1548 bytes (total 512, permanent 512):
384 in free list (128 min, 1024 max allowed)
16524 hits, 80 misses, 118 trims, 118 created
Private particle pools:
FastEthernet0/0 buffers, 1548 bytes (total 192, permanent 192):
0 in free list (0 min, 192 max allowed)
192 hits, 0 fallbacks
192 max cache size, 128 in cache
464870504 hits in cache, 16232 misses in cache
Serial0/0 buffers, 1548 bytes (total 48, permanent 48):
0 in free list (0 min, 48 max allowed)
48 hits, 0 fallbacks
48 max cache size, 24 in cache
570887849 hits in cache, 76 misses in cache
08-30-2008 04:10 PM
If you're running a recent IOS, you might try buffers tune automatic. Otherwise, this tech note document, http://www.cisco.com/en/US/products/hw/routers/ps133/products_tech_note09186a00800a7b80.shtml, should help you with manual tuning.
08-31-2008 11:14 AM
thanks joseph for the link, but i was specifically concern tuning LARGE and HUGE buffersand wanted to increase them. on the link it says:
*permanent: take the number of total buffers in a pool and add about 20%.
*min-free: set min-free to about 20-30% of the permanent number of allocated buffers in the pool.
*max-free: set max-free to something greater than the sum of permanents and minimums.
my question is how am i going to compute/configure for these if total is 1 and permanent is 0?
08-31-2008 11:32 AM
Round up. I.e. starting with zero or one, add 1. Since peak was 4 and 2, you also could try increasing to up peak for both. Monitor results.
If you're not tight on free RAM, it's easier to be generous when increasing buffer values. I suspect initial default values probably more tied to when router RAM was more restricted, and/or large MTU (e.g. jumbo Ethernet) wasn't possible or as common.
