Need help configure T1 DSU/CSU wic card on two 3640s
Eric Boadu
Hello Guys,
I have configued two T1 dsu/csu card on two Ciso 3640.Back-to-back for my lab. I used RJ45 crossover cable between them. Both cards are in alarm(AL) what protocol or permeter that I am missing to make both routers talk to each other? See beloow and advised.
Router1
serial 2/0
ip address 10.10.11.2 255.255.255.0
service-module t1 clock source line
service-module t1 data-coding normal
service-module t1 timeslots all speed 64
service-module t1 framing esf
service-module t1 lbo none
service-module t1 linecode b8zs
no service-module t1 remote-alarm-enable
no service-module t1 fdl
encapsulation frame-relay
frame-relay lmi-type cisco
frame-relay interface-dlci 105
Router2
Router1
serial 2/0
ip address 10.10.11.1 255.255.255.0
service-module t1 clock source internal
frame-relay interface-dlci 501
Thx,
Eric
2 Accepted Solutions
can u please paste the config for both the routers or atleast both connected interfaces?
any cisco router 2500 or higher should be ok as frame-switch, you will need enough ports/interfaces in the router depending number of routers you want to connect. some links:
http://www.ciscopress.com/articles/article.asp?p=170741&seqNum=7
http://www.thebryantadvantage.com/Frame%20Relay%20Switch.htm
13 Replies 13
tdrais
Level 7
Level 7
a rj45 cross won't work. You need 1-4 2-5 cable
Hello Tdrais,
Thanks for responding; can you be more specific about the cables? what type of cable should I get to make these two router communicates? you mean the cat 5 cable pin out?
Thx,
Eric
I assume someone sells these but I always just make them.
This link has a good picture.
http://help.pbxtra.com/index.php/T1_crossover_HOWTO
Thanks Tdrais, Both DSU/CSU CD led light are green but no link between both routers. Any idea >>add or remove?
Serial2/0 is down, line protocol is down
Hardware is QUICC with integrated T1 CSU/DSU
Internet address is 10.10.10.2/24
MTU 1500 bytes, BW 1536 Kbit, DLY 20000 usec,
Encapsulation HDLC, loopback not set
Keepalive set (10 sec)
Last input never, output never, output hang never
Last clearing of "show interface" counters 00:07:19
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/0/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 1152 kilobits/sec
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 unknown protocol drops
0 carrier transitions
DCD=down DSR=up DTR=up RTS=up CTS=down
Internet address is 10.10.10.1/24
Last clearing of "show interface" counters 00:17:25
you can do back to back connection between 2 t1 csu/dsu, check this link:
http://www.cisco.com/en/US/products/hw/routers/ps233/products_tech_note09186a00800a3f09.shtml
u can use the pinout to build the cross over t1 cable.
but i think u cant use frame-relay as layer 2 protocol though without a frame switch connceted in between or have a cisco router acting as frame switch, but u should be able to use ppp as layer 2 protocol
Rajib,
I have pin out cable correctly CD led light is up and change the serial int to encap PPP but still no link between them. This is driving me crazy as I could not resolute this issue. Any idea??
ATM#sh service-module
Interface Serial2/0
Module type is T1/fractional
Hardware revision is 0.128, Software revision is 20050811-0.3,
Image checksum is 0x80ACD1B3, Protocol revision is 0.1
Transmitter is sending remote alarm.
Receiver has no alarms.
Framing is ESF, Line Code is B8ZS, Current clock source is line,
Fraction has 24 timeslots (64 Kbits/sec each), Net bandwidth is 1536 Kbits/sec.
Last module self-test (done at startup): Passed
Last clearing of alarm counters 01:29:19
loss of signal : 0,
loss of frame : 0,
AIS alarm : 0,
Remote alarm : 0,
Module access errors : 0,
Total Data (last 0 15 minute intervals):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Data in current interval (0 seconds elapsed):
Interface Serial2/1
Hardware revision is 0.80, Software revision is 20050811-0.3,
Receiver has loss of signal, loss of frame,
Last clearing of alarm counters 01:29:27
loss of signal : 1, current duration 01:29:15
loss of frame : 1, current duration 01:29:15
AIS alarm : 0,
Remote alarm : 0,
I have attached both routers config. Please advise as why I could not make both talk to each other. My T1 crossover cable as follow
1 >> 4
2 >> 5
4 >> 1
5 >> 2
CD led light is green on both card and Orange AL (alarm) light on both card as well.
Please advise asap!
Thx,
Eric
I got it resolved after try and errors procedures on both routers. Make clocking source line on both end do not make other end internal that was my problem. If you fellow below config yours will work fine. Thank you all for your help and advised.
encapsulation hdlc
bandwidth 1544
****A t1 crossover is pinned this way:
1 -> 4
2 -> 5
4 -> 1
5 -> 2
Cheers,
Eric
glad to know that u got it resolved
Rajib,
What or which cisco device would be good for as frame-relay switch? I have 3640 with 4 dsu/csu card can I make this router act as frame switch?. Please advice
E
Thanks Raj!
