Usage of null0
mahmoodmkl
Level 7
Level 7
Hi Guys,
Can anyone explain me the useage of null0 in the routing table.
Why it is used and in which situation we should use it.
Any help is appreciated.
Mahmood
8 Replies 8
Marwan ALshawi
null0 used in some kinds of route blocking
which is called balck holing
for eaxmple instead of makeing ACL and block the route in ur router
u can recieve that route and make it point to null0 so it will be blocked and less CPU intenssive when u block it with ACL
for example u might want to block route going to 192.168.1.0/24
just do it like
ip route 19.168.1.0 255.255.255.0 null0
also this null0 will apear in the routing table whn u use summarization with eigrp
but when u see the summary address with null0 as next hop interface that mean this router is generating that summaty route (not blocking in this case)
if helpful Rate
Thanks for your reply.
How does it prevent from route block holing can anyone please explain me with a example.
I m missing concept here.
Mahmood
lets take this simple example
router1----router2--10.1.1.0/24
router1 has a route to 10..1.1.0/24 point to router2 as the next hop
on router2
u make the null0 config like
ip route 10.1.1.0 255.255.255.0 null0
in this case a packet going to 10.1.1.0/24 from router1 will be send to router2 router2 will take this packet ( not drop it) then send it to the route with null0 then the route will not actually be forward to that network and then u block it but with out any deny or ACL
if helpful Rate
If it is used in EIGRP and EIGRP is advertising a summary route in this case how the null0 works
Mahmood
hi Mahmood
hope evrything is well
ok with eigrp summary route the summarized route in the routing table will looks like :
D 2.1.0.0/16 is a summary, 00:00:22, Null0
lets say this is router1
Notice that the summary route is sourced from Null0, and not an actual interface. That is because this route is used for advertisement purposes and does not represent a path that router1 can take to reach that network. On router1, this route has an administrative distance of 5
so any router connected to router one can send packect going to any address within the summary address range and router1 will have route for the more spesific route when come to it like in our example 2.1.1.0/24 through interface 1 and 2.1.2.0/24 through interface 2 and so on, but the nieghbor routers will see only the summary route and router1 as a next-hop
this is useful with larg routing tables
thank you
if helpful rate
If all addresses have more specific routes on the summary router then the null0 is not really needed and will have no effect. It is used in case part of the network being summarized does not exist.
For example say I have
10.10.2.0/24 and 10.10.3.0/24 but I summarize it to 10.10.2.0/23. This will generate a 10.10.2.0/23 null0 route in the summary router but since I have routes to both the /24 these will override the null0 since they are more specific.
Now lets say I do the same summary but 10.10.3.0/24 is down and therefore not in the routing table. A packet sent to 10.10.3.x will now use the 10.10.2.0/23 null0 route and the packet will be dropped. This is mostly used to prevent routing loops especially when you have default routes configured.
hi tim
but the source of
"Notice that the summary route is sourced from Null0, and not an actual interface. That is because this route is used for advertisement purposes and does not represent a path that router1 can take to reach that network. On router1, this route has an administrative distance of 5 "
is cisco networking academy !
however ur idea is reasonable as well :)
Danilo Dy
You will be surprise the many use of Null0.
- Blackhole
- EIGRP route summarization
- BGP route aggregation
- NAT
- Routing loops
Those so far I found out and use over so many years in networking.
