Redundancy for single IDSM on two separate chassis
Answered Question
Aug 31st, 2008
Can EtherChannel protocol be used to provide active/standby redundancy for single IDSM on two different chassis.
Rgds.
Correct Answer by Farrukh Haroon about 8 years 6 months ago
The failover will be based on HOW your FWSM mac-address is learnt by the 'inside' devices. Under normal operation The PRIMARY FWSM will be active so all traffic will pass through the IDSM present on that Core Sw. When FWSM failovers all traffic will pass through the SECONDARY FWSM and the IDSM module in the second chassis.
Farrukh
Overall Rating: 5 (1 ratings)
Farrukh Haroon Sun, 08/31/2008 - 19:05
  • Red, 2250 points or more
new_networker Mon, 09/01/2008 - 02:15
From the given link, I understand that active/standby redundancy configuration is not possible for IDSM's on two different chassis. Only active/active is possible.
Secondly, please let me know whether the below configuration is for two IDSM's within same chassis or across two separate chassis.
intrusion-detection module 4 management-port access-vlan 100
intrusion-detection module 5 management-port access-vlan 100
intrusion-detection module 4 data-port 1 channel-group 5
intrusion-detection module 4 data-port 2 channel-group 6
intrusion-detection module 5 data-port 1 channel-group 5
intrusion-detection module 5 data-port 2 channel-group 6
intrusion-detection port-channel 5 trunk allowed-vlan 200-204,208
intrusion-detection port-channel 5 trunk allowed-vlan 708
intrusion-detection port-channel 5 autostate include
intrusion-detection port-channel 5 portfast enable
intrusion-detection port-channel 6 trunk allowed-vlan 260,280,400,401
intrusion-detection port-channel 6 trunk allowed-vlan 111-114
intrusion-detection port-channel 6 autostate include
intrusion-detection port-channel 6 portfast enable
Rgds.
Farrukh Haroon Mon, 09/01/2008 - 06:17
You can achieve active/standby with spanning tree. You need to tell more detail about your topology to comment further.
This is for two IDSMs installed in the same chassis.
Farrukh
new_networker Mon, 09/01/2008 - 06:25
My scenario is two Cat 6500 Chassis with similar FWSM, ACE, IDSM modules in each.
Now I need to configure redundancy for the IDSM module only in each 6500 chassis.
Thanks.
Farrukh Haroon Mon, 09/01/2008 - 08:03
How is your FWSM setup? MSFC Outside or MSFC inside?
Farrukh
Correct Answer
Farrukh Haroon Mon, 09/01/2008 - 19:06
Farrukh
new_networker Mon, 09/01/2008 - 19:58
In short, there is no provision for independnent IDSM failover across two chassis.
Thanks.
