VPN client IP address
Aug 31st, 2008
How I can fix the IP address for the VPN client which is connected through an ISP 3800 router.
I want to use that to apply access-lists to clients connected with VPN.
Overall Rating: 3.7 (3 ratings)
Marwan ALshawi Sun, 08/31/2008 - 20:37
if u asking about vpn client ip
it is in the ip address pool
i f u need assistance i ur config just post ur config here and tell me what u wanna do with it
omar.elmohri Mon, 09/01/2008 - 00:38
No I'm not talking about creating a pool. I want to give each client a fixed IP address that will use it for any other time it connects.
Marwan ALshawi Mon, 09/01/2008 - 01:41
if u wanna make this thing to few users one, two or three
u can make treck
lets say u wanna assign this ip to a spisific client
creat a new pool and make the starting and ending ip as
then creat new vpn group and assin this new address pool to it
in this case u can garntee this user will take only this ip
u can rpeat this idea for evry user u want it to have a spisific ip
but this works for few number of users
good luck
please, if helpful Rate
Marwan ALshawi Mon, 09/01/2008 - 18:59
hi Jagdeep
i think the nice link u have post it here exactly dose the same idea i have mentioned above
although it is for PIX but the idea is aplicable on a router as well :)
then we agree that this way will let Omar achieve his goal with this method
however as i mentioned above it is aplicable for saml number of useres because it is not scaleable
for large number of users iw ould say authentication with ACS AAA and on ACS we can make static IP assignment from there
thank you
and good luck Omar
omar.elmohri Wed, 09/03/2008 - 03:27
This what I'm thinking that this solution is not scalable. And I want to use a method while keeping the same vpngroup.
As I don't have an ACS in this solution, I can only use the method you mention it.
I tried to do that using AAA on the router but that don't give a solution.
