robertson.michael Sun, 08/31/2008 - 10:29
  • Silver, 250 points or more
Hi Celso,
If you simply want to refer to hostnames within your configuration rather than IP addresses, you can use the 'name' command. So, your configuration could look something like this (taken from the ASA command reference):
hostname(config)# names
hostname(config)# name 192.168.42.3 sa_inside
hostname(config)# name 209.165.201.3 sa_outside
hostname(config-if)# ip address inside sa_inside 255.255.255.0
hostname(config-if)# ip address outside sa_outside 255.255.255.224
Also, here is a link to that command reference:
http://www.cisco.com/en/US/docs/security/asa/asa80/command/reference/no.html#wp1747000
Hope that helps.
-Mike
cfajardo1_2 Sun, 08/31/2008 - 22:46
thx but what am asking is if theres a way to add a dns ip and the asa will do a lookup there for name resolution rather than doing all this harcoded names on asa?
ariesc_33 Mon, 09/01/2008 - 19:51
i had to create hundreds of names and groups manually on the firewall to simplify my configuration.
this is a good question, hope someone can clarify this.
robertson.michael Tue, 09/02/2008 - 08:24
Unfortunately, this is not possible. You must use either an IP address or a name (configured with the 'name' command mentioned above) in the firewall's configuration. You can also use object-groups to condense ACLs, but again this all must be manually entered at least once into the firewall's configuration.
-Mike
cfajardo1_2 Sun, 09/07/2008 - 09:09
so it seems it is not possible at all...thx a lot gents
