consultative transfer not working
Aug 31st, 2008
Hi all,
I use cme4.1 with 12.4(15)T4 IOS.
After I set some translation profiles and rules for separate accounting purpose (shared call manager between 3 companies with separate voice ports) the full-consultative transfer stopped to work. When I want to transfer, both calls remain in hold state and I get a busy tone, although the local-consultative and blind transfer is still working.
However when I set the local-consult transfer and I want to initiate a three party hardware assisted ad-hoc conference only 2 party-s are joined the third party is dropped. If I set back to blind transfer the three party conference call is working fine.
Here is my related conf:
voice translation-rule 1
rule 1 /^9/ /19/
voice translation-rule 2
rule 1 /^9/ /29/
voice translation-rule 3
rule 1 /^9/ /39/
voice translation-profile AMGAZ
translate called 3
voice translation-profile DIRECTONE
translate called 2
voice translation-profile PIAR
translate called 1
dial-peer voice 1 pots
translation-profile incoming AMGAZ
answer-address 6..
dial-peer voice 3 pots
translation-profile incoming PIAR
answer-address 8..
dial-peer voice 2 pots
translation-profile incoming DIRECTONE
answer-address 7..
dial-peer voice 600 pots
corlist outgoing call-mobile
description AMGAZ-Mobile Calls
destination-pattern 1907[0-9].......
port 0/0/0
forward-digits 10
dial-peer voice 601 pots
corlist outgoing call-national
description AMGAZ-National Calls
destination-pattern 190[1-5]........
port 0/0/0
forward-digits 10
dial-peer voice 700 pots
description DIRECTONE-Mobile Calls
destination-pattern 2907[0-9].......
port 0/0/1
forward-digits 10
dial-peer voice 701 pots
description DIRECTONE-National Calls
destination-pattern 290[1-5]........
port 0/0/1
forward-digits 10
telephony-service
sdspfarm conference mute-on 111 mute-off 222
sdspfarm units 4
sdspfarm tag 1 confprof1
sdspfarm tag 2 transcod1
conference hardware
load 7960-7940 P0030702T023
load 7911 P00307020200
max-ephones 96
max-dn 288
ip source-address 10.10.10.1 port 2000
service phone videoCabability 1
system message CCME4.1
url services http://phone-xml.berbee.com/menu.xmlopts=1234567
time-zone 34
time-format 24
date-format dd-mm-yy
max-conferences 8 gain -6
call-park system redirect
call-forward pattern .T
moh music-on-hold.au
multicast moh 239.1.1.1 port 2000
dn-webedit
time-webedit
transfer-system local-consult
transfer-pattern .T
secondary-dialtone 9
login timeout 1
Any help would be appreciated!
Oszkar
htarra Fri, 09/05/2008 - 09:35
  • Bronze, 100 points or more
I think you are missing the transfer pattern.In Cisco Unified CME 4.0(1) and later versions, the line button for a monitored line can be used as a DSS for a call transfer when the monitored line is in-use, provided that the actual call transfer can succeed; for example, when the monitored line is configured for Call Forward Busy or Call Forward No Answer.
