6509 Sup7203BXL Error
Aug 31st, 2008
Has anyone of you seen this error? I tried to use Cisco Output
Interpreter but haven't seen any information about the error. Thanks.
000747: Aug 29 20:16:10.000 UTC: %DUMPER-3-PROCINFO: pid = 16426:
(sbin/udp.proc), terminated due to signal SIGSEGV, Segmentation
violation (Address not mapped)
000748: Aug 29 20:16:10.000 UTC: %DUMPER-3-REGISTERS_INFO: 16426:
zero at v0 v1
000749: Aug 29 20:16:10.000 UTC: %DUMPER-3-REGISTERS_INFO: 16426: R0
00000000 7228D517 00000000 00000000
000750: Aug 29 20:16:10.000 UTC: %DUMPER-3-REGISTERS_INFO: 16426:
a0 a1 a2 a3
000751: Aug 29 20:16:10.000 UTC: %DUMPER-3-REGISTERS_INFO: 16426: R4
0106136C 01061358 000007E9 0000402A
000752: Aug 29 20:16:10.000 UTC: %DUMPER-3-REGISTERS_INFO: 16426:
t0 t1 t2 t3
000753: Aug 29 20:16:10.000 UTC: %DUMPER-3-REGISTERS_INFO: 16426: R8
00000000 00000001 00000004 00000001
000754: Aug 29 20:16:10.000 UTC: %DUMPER-3-REGISTERS_INFO: 16426:
t4 t5 t6 t7
000755: Aug 29 20:16:10.000 UTC: %DUMPER-3-REGISTERS_INFO: 16426: R12
CDD182FC D05155F1 FF000000 00000000
000756: Aug 29 20:16:10.000 UTC: %DUMPER-3-REGISTERS_INFO: 16426:
s0 s1 s2 s3
000757: Aug 29 20:16:10.000 UTC: %DUMPER-3-REGISTERS_INFO: 16426: R16
00000000 00F71930 01061358 00F71948
000758: Aug 29 20:16:10.000 UTC: %DUMPER-3-REGISTERS_INFO: 16426:
s4 s5 s6 s7
000759: Aug 29 20:16:10.000 UTC: %DUMPER-3-REGISTERS_INFO: 16426: R20
01061340 6C0BA940 7C263170 01061138
000760: Aug 29 20:16:10.000 UTC: %DUMPER-3-REGISTERS_INFO: 16426:
t8 t9 k0 k1
000761: Aug 29 20:16:10.000 UTC: %DUMPER-3-REGISTERS_INFO: 16426: R24
7264CCA4 76117C90 00000000 00000000
000762: Aug 29 20:16:10.000 UTC: %DUMPER-3-REGISTERS_INFO: 16426:
gp sp s8 ra
000763: Aug 29 20:16:10.000 UTC: %DUMPER-3-REGISTERS_INFO: 16426: R28
7C5715E0 00F718F0 00F71918 7646AFF4
000764: Aug 29 20:16:10.000 UTC: %DUMPER-3-REGISTERS_INFO: 16426:
sr lo hi bad
000765: Aug 29 20:16:10.000 UTC: %DUMPER-3-REGISTERS_INFO: 16426: R32
1000FC73 00000000 00000000 0000010C
000766: Aug 29 20:16:10.000 UTC: %DUMPER-3-REGISTERS_INFO: 16426:
cause pc epc
000767: Aug 29 20:16:10.000 UTC: %DUMPER-3-REGISTERS_INFO: 16426: R36
00800008 7646B038 00000000
000768: Aug 29 20:16:10.000 UTC: %DUMPER-3-TRACE_BACK_INFO: 16426:
(s72033_rp-adventerprisek9_
wan-64-dso-p.so+0x2038)
(s72033_rp-adventerprisek9_wan-51-dso-p.so+0x10324)
(s72033_rp-adventerprisek9_wan-51-dso-p.so+0x16100) (libc.so+0x48204)
(libc.so+0x47EC4) (s72033_rp-adventerprisek9_wan-1-dso-p.so+0x5B64)
(s72033_rp-adventerprisek9_wan-1-dso-p.so+0x5B04)
(s72033_rp-adventerprisek9_wan-1-dso-p.so+0x507C)
(s72033_rp-adventerprisek9_wan-1-dso-p.so+0x397C)
(s72033_rp-adventerprisek9_wan-1-dso-p.so+0x3F48) (libc.so+0x252D4)
(libc.so+0x127AC)
000769: Aug 29 20:16:11.000 UTC: %DUMPER-3-CRASHINFO_FILE_NAME: 16426:
Crashinfo for process sbin/udp.proc at
bootflash:/crashinfo_udp.proc-20080829-201610
000770: Aug 29 20:16:11.000 UTC: %DUMPER-6-BAD_PATH: 16426: Choice 1
either not configured or bad path. Trying next choice.
000771: Aug 29 20:16:11.000 UTC: %DUMPER-6-BAD_PATH: 16426: Choice 2
000772: Aug 29 20:16:11.000 UTC: %DUMPER-6-BAD_PATH: 16426: Choice 3
000773: Aug 29 20:16:12.000 UTC: %DUMPER-3-DUMP_FAILURE: 16426: Core
dump failed: Could not create core
000774: Aug 29 20:16:12.000 UTC: %SYSMGR-3-ABNORMTERM: udp.proc:1 (jid
98) abnormally terminated, restart scheduled
000775: Aug 29 20:16:13.000 UTC: %SYSMGR-6-RESPAWN: Process udp.proc:1
has been respawned
John
Giuseppe Larosa Sun, 08/31/2008 - 22:39
  • Hall of Fame,
    Founding Member
Hello John,
the tool to be used should be the error message decoder but it doesn't provide any answer.
I haven't found any ref in the error and system messages guide for release 12.2SX.
I can say that these messages have been written by a process DUMPER that is trying to create a core dump just after a crash.
An error occurred during this process and so a detailed list of steps is provided.
the overall result is that the core dump could not be created.
Hope to help
Giuseppe
John Patrick Lopez Mon, 09/01/2008 - 14:27
Hey thanks for the reply. So what's this? Is this a hardware or software issue? Can this be resolved by updating the Cisco IOS? Thanks.
Giuseppe Larosa Mon, 09/01/2008 - 23:16
  • Hall of Fame,
    Founding Member
Hello John,
the core dump is written when a crash happens.
I think this is a software issue you can think of an IOS upgrade.
Hat it happened only once or more times ?
Hope to help
Giuseppe
