Changing IP address of the Call manager
Aug 31st, 2008
I have changed the IP address of the call manager pub and sub. After changing the IP address of the Pub and Sub and set up a DHCP scope on the Pub, all the IP phones cannot connect to the call manager as it still pointing to the old TFTP server IP address..
Without manually going through the process of changing the TFTP IP address for each phone, how can I update that the tftp address to point to the new TFTP IP address?
rachelau_2005 Tue, 08/26/2008 - 06:29
I have already done that
all the ip phones got the new ip address, but the tftp stay the same
I have set up 150 tftp as a predefined option in the scope. but the ip phones still havent pick up the tftp address.
any other idea?
Jaime Valencia Sun, 08/31/2008 - 19:32
do a shut, no shut of the switch port from a phone and try again
also verify the configuration from within CCM has been changed if any element has been defined as using IP address
phones should receive all the config from the DHCP and accept it, make sure you did the changes to the right pool
if this helps, please rate
rachelau_2005 Sun, 08/31/2008 - 19:57
I have reset the switch port again, for those phone which have "alternate TFTP address" disabled, it works and can register to the call manager now.
However for those phones that has " alternate TFTP Address" enabled, it still keep registering to the old TFTP ip address. Since I have over 100 phones with "alternate tftp address" enabled, is there any way that I dont have to manually disable the "alternate TFTP address" on each phone?
Poongundran Ven... Mon, 09/01/2008 - 01:12
Release IP address from your phone, your current configuration erased, now phone looking new TFTP and DHCP.
