Accessing 2 vlan from one NIC
Aug 31st, 2008
Hi all,
I have requirement to access two vlan from my PC.
I have configred the LAN switch(cisco 2960G) as trun port,In my NIC intel 82566-dm2 gigabit ethernet card configured two vlans.
But it is not working..
If any setting to be done on the switch apart from configuring it as trunk port.
Dileep
satish_zanjurne Sun, 08/31/2008 - 23:03
  • Silver, 250 points or more
Does this NIC supports TRUNKING/TAGGING, Native VLAN??
satish_zanjurne Mon, 09/01/2008 - 00:25
Then apart from regular config like
switchport mode trunk
Also make sure Native VLAN is same on both sides.
This should work...
Dileep Sivadas ... Mon, 09/01/2008 - 23:31
my issue is resolved..
the problem was with trendmicro office scan installed on that pc and it has firewall and IDS features.After i disabled the firewall on network card both VLANs are working fine.
satish -thanks for reply
