reg:switches
Aug 31st, 2008
Dear sir,
Iam confusing the switch which model is suitable.
1)managed switch with 22 10/100 ports and 2 dual-personality ports for 10/100/1000 connectivity or optional fiber uplinks.
2)Layer 2, 48-port 10/100 switch with 2 dual-personality Gigabit ports providing 10/100/1000T or mini-GBIC connectivity.
can anybody suggest me.
Thanks&Regards
srini
Mark Yeates Mon, 09/01/2008 - 00:05
  • Gold, 750 points or more
Here are the the switches that will best suit your posted requirements.
1:) 2960-24TC-L (24 Ethernet 10/100 ports and 2 dual-purpose uplinks)
2:) 2960G-48TC-L (44 Ethernet 10/100/1000 ports and 4 dual-purpose uplinks)
These switches will utilize SFP modules for fiber connectivity.
HTH,
Mark
satish_zanjurne Mon, 09/01/2008 - 00:17
  • Silver, 250 points or more
Understand what is your requirement ?
More port density is always advantage.You can go for Catalyst 3560 WS-C3560-48TS-S
with standard image(SMI) for your L2 requirement.
Cisco Catalyst 3560-48TS: 48 Ethernet 10/100 ports and 4 SFP-based Gigabit Ethernet ports; 1RU
If L3 requirement arises in future you can always upgarde the image to EMI without changing the hardware.
HTH..
