PIX 525 internet degradation after upgrade
Sep 1st, 2008
Hello
we have upgraded the version 6.3.5 to 7.2 (3) on a PIX 525 .
Our client has got a 1000 user network and report problem of internet download latency that increase about 200 % .
example: a 100 Mbyte file take 5 minutes before the upgrade . Now takes 15 or 20 minute
The carrier ( STM-1 lines ) do not report any changes over the line.
We have just fix up the issue over the ftp connection using the class-map method and allow MSS with higher range
But this problem could not fix yet with this method
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a00804c8b9f.shtml
Any other suggestion ?
Alberto Belleli
PS Coordinator Network Security
Cisco CCNP/CCDP
Uniautomation SpA
Via dell'Artigianato 2/B
20061 Carugate - Italy
jdive Mon, 09/01/2008 - 04:23
  • Cisco Employee,
Big difference between pix 6.x and 7.X is the tcp statefull engine that got quite of a lift up. It is much more aggressive in dropping suspicious TCP segments or sanitizing the various headers. It would be ideal to find a reproducable scenario: downloading this file on this site via HTTP / FTP. Once this is done, check the asp drops counters or enable asp drop capture (capture bla type asp_drop) , check the logs as well during the transfert to see if any segments have been dropped and why. If this does not give anything, getting a smaller file and enabling capture on inside/outside at the same time would help in seeing what in the packet changes, the delay in crossing the PIX and the packet drops / retransmits and so forth.
abelleli71 Mon, 09/01/2008 - 04:40
Hello
thanks for the reply . This procedure is similare for the MSS reduction that we try already to fix with this ( without success ) :
pixfirewall(config)#access-list http-list4 permit ip any any
pixfirewall#configure terminal
pixfirewall(config)#class-map http-map4
pixfirewall(config-cmap)#match access-list http-list4
pixfirewall(config-cmap)#exit
pixfirewall(config)#tcp-map mss-map
pixfirewall(config-tcp-map)#exceed-mss allow
pixfirewall(config-tcp-map)#exit
pixfirewall(config)#policy-map http-map4
pixfirewall(config-pmap)#class http-map4
pixfirewall(config-pmap-c)#set connection advanced-options mss-map
pixfirewall(config-pmap-c)#exit
pixfirewall(config-pmap)#exit
pixfirewall(config)#service-policy http-map4 interface inside
pixfirewall#
abelleli71 Mon, 09/01/2008 - 05:32
Here it the output of a transaction
DNS reply from outside:192.228.79.201/53 to dmz:193.205.23.1/36259; packet length 530 bytes exceeds configured limit of 512 bytes messages:Sep 1 15:21:20 pix-primary.uni-bocconi.it Sep 01 2008 15:23:01: %PIX-4-410001: Dropped UDP DNS reply from outside:192.228.79.201/53 to dmz:193.205.23.1/17440; packet length 530 bytes exceeds configured limit of 512 bytes messages:Sep 1 15:21:20 pix-primary.uni-bocconi.it Sep 01 2008 15:23:01: %PIX-4-410001: Dropped UDP DNS reply from outside:192.228.79.201/53 to dmz:193.205.23.1/1686; packet length 529 bytes exceeds configured limit of 512 bytes
grant.maynard Tue, 09/02/2008 - 14:14
  • Silver, 250 points or more
DNS response being dropped because they're too long? Try this:
policy-map type inspect dns MY_DNS_INSPECT_MAP
parameters
message-length maximum 600
policy-map global_policy
class inspection_default
grant.maynard Wed, 09/03/2008 - 01:25
or just edit the default policy, if it's there:
policy-map type inspect dns preset_dns_map
parameters
abelleli71 Wed, 09/03/2008 - 01:29
Hello
I just cut of the parameter doing :
parameters
no message-length maximum 512
But nothing seems to change . I have checked also the show asp drops with the following resuslts:
Frame drop:
Invalid encapsulation 526
Invalid IP length 40830
Invalid TCP Length 1326
Invalid UDP Length 71
No route to host 4
Flow is denied by configured rule 116709
First TCP packet not SYN 59875
Bad TCP flags 282
Bad option length in TCP 212
TCP Dual open denied 32
TCP failed 3 way handshake 1253
TCP RST/FIN out of order 1018
TCP SEQ in SYN/SYNACK invalid 398
TCP SYNACK on established conn 19
TCP packet SEQ past window 1292
TCP invalid ACK 234
TCP ACK in 3 way handshake invalid 3
TCP Out-of-0rder packet buffer full 17816
TCP Out-of-Order packet buffer timeout 5799
TCP RST/SYN in window 345
TCP DUP and has been ACKed 237343
TCP packet failed PAWS test 2189
Slowpath security checks failed 251
ICMP Error Inspect no existing conn 20
ICMP Error Inspect different embedded conn 102
DNS Inspect invalid packet 35
DNS Inspect invalid domain label 226
DNS Inspect packet too long 4002
DNS Inspect id not matched 294
FP L2 rule drop 5703
Flow drop:
Flow is denied by access rule 30
NAT failed 636
Inspection failure 3590
pix-primary#
grant.maynard Wed, 09/03/2008 - 03:02
I meant increase the limit. I'm not sure that removing it would have the same effect.
parameters
mcvhintex Thu, 09/04/2008 - 13:45
This sounds very familiar to an issue we had with DNS Fixup in PIX 6.35. The DNS maximum was set to 512 and we had to increase its default size. Perhaps the fixup value was not default before the upgrade and the value was reset.
The suggested method to change it in 7.x is:
hostname(config)# policy-map type inspect dns dns-inspect
hostname(config-pmap)# parameters
hostname(config-pmap-p)# message-length maximum 1024
abelleli71 Thu, 09/04/2008 - 22:58
Hello
thanks for the answer . We have already cut of the parameters and try also the 1024 size ...but nothing seems to change .
The problem was that we have an internet speed degradation . Before upgrade was 200 Kb/s now is around 90 Kb/s . No change on the provider.
Question :
The only log that we see during a download is that one that I stamp in the previuos message .
Is the DNS the only responsable for a download session ?
