Upgrading Callmanager 4.x to 6.x
Sep 1st, 2008
Can anyone confirm if the following are migrated during the upgrade via DMA:
Speed Dials
Fast Dials
Call Forwards
Reza
rsadiq Mon, 09/01/2008 - 05:28
Hi Rob
Thanks for coming back. The links seems to cover PAF, Speed and Fast dials ok. Does the same apply to Call Forwards set by users, as that is likely to be stored in the CM database also right?
Reza
Rob Huffman Mon, 09/01/2008 - 05:42
Hi Reza,
You are most welcome my friend :) Sorry, I missed the Call Forward aspect. Yes the Call Forward settings should migrate over as well.
Hope this helps!
Rob
