UC500 service module error
Answered Question
Sep 1st, 2008
Hi every one i have following issue
I have uc500 and after while the Autoattendant dosent work , incomng calls keep ringing without going to Auto attendant, i check the service model status it give me this errors like SERVICE MODULE WAIT FOR REGESTER MESSAGE
the it said it ready and i can enter , when i enter it just keep reloaing and attached file for all output.
any help please ?
Correct Answer by paolo bevilacqua about 8 years 2 months ago
Type *** when the bootloader so prompts, and proceed from there to re-install.
Note, you have hardware errors accessing the disk (actually a flash memory), not sure if re-installing will fix that.
Overall Rating: 3.5 (4 ratings)
jbayuka Fri, 09/05/2008 - 13:48
  • Bronze, 100 points or more
Set up CFB and CFNA and update and then restart phone.
motasemkhater Sun, 02/15/2009 - 02:32
can you tell me whats is CFP, CNFA ?
it will be a great help if you have a link shows how to set these things ?
paolo bevilacqua Sun, 02/15/2009 - 02:59
  • Hall of Fame,
    Founding Member
Hi, you have to reload software for the service module, as it is not going online.
motasemkhater Sun, 02/15/2009 - 03:06
I have the stupid UC520..the CUE crash after memory got full of Voice mails(its a bug[CSCeh55158.] ) so i did the recovery and went fine , after 6 months crash again so i try to do the recovery again with the latest CUE 3.2.2 ,,, i don't know what happens but i cant access the ISE any more ... please check the attached file for the output i get
this is where i stand SIR
can you check the attached file ?
paolo bevilacqua Sun, 02/15/2009 - 03:43
  • Hall of Fame,
    Founding Member
You should have response, try having session in one terminal, and service module reset in another.
After, try loading the very latest UC500 software for CUE.
motasemkhater Sun, 02/15/2009 - 03:51
you mean that reload the module and try to Telnet 10.1.10.1 2002 (Service module IP) from CMD in my PC ?
attach is the UC500-CME configuration
paolo bevilacqua Sun, 02/15/2009 - 03:57
  • Hall of Fame,
    Founding Member
No. In one terminal, do service-module session as you did already. In another terminal, do service-module reset.
Configuration doesn't matter.
If there is no known method to unblock CUE, you can only reload software. Hopefully you had a backup.
Correct Answer
paolo bevilacqua Sun, 02/15/2009 - 04:30
  • Hall of Fame,
    Founding Member
