Callmanager express
Sep 1st, 2008
dear all
I have orederd a cisco 3845 vocie bundel.
in its description there is FL-CCME-240
but when I recived my box there was no Fl-CCME-240
I called cisco and they told me that its activated on your cisco IOS
how can I find or verify this?
thank you
rob.huffman Mon, 09/01/2008 - 05:00
Hi Amir,
The 3845 does supprt 240 IP Phones by default. Here is a way to check;
The max-ephones command limits the number of Cisco IP phones supported on the router. The maximum number you can set is platform- and version-dependent. Use CLI help to determine the maximum number of ephones you can set, as shown in this example:
Router(config-telephony)# max-ephones ?
<1-240> Maximum phones to support
Hope this helps!
