Warning message
Linux OS Healthcheck
Sep 1st, 2008
Hello, we are planning to install CUCM 6 but our boss ask us about linux OS healthcheck. What is the Cisco procedure if we need to patch something on OS itself and is this happend often ?? Best Regards.
Jaime Valencia Mon, 09/01/2008 - 07:35
  • Cisco Employee,
  • Hall of Fame,
    2011
you cannot patch the OS itself, the only way to patch the OS would be to install the SR or ES for your CUCM version and not all files contain OS fixes.
how often?? whenever a new SR is released and posted at CCO
java
if this helps, please rate
christophe.terp... Mon, 09/01/2008 - 22:51
Hello, this means it is impossible to patch OS like if there is SSH vulnerability for example ??
Jaime Valencia Tue, 09/02/2008 - 06:22
  • Cisco Employee,
  • Hall of Fame,
    2011
yes, you can only install patches provided from Cisco. If the patch you're looking for is in the SR or ES then you just need to install it, if not, there is no way to install non-cisco provided patches
java
