Rate limiting not working on 6504E
Sep 1st, 2008
I limit my customers on 6504E using rate-limiting but the customers shoot beyond the rate-limit.I configure rate-limiting on Cisco 6504E with the following cards:
IOS:
s72033-advipservicesk9_wan mz.122-18.SXF8.bin
Cards
Supervisor Engine 720 (Active) WS-SUP720-3B
SFM-capable 16 port 10/100/1000mb RJ45 WS-X6516-GE-TX
interface GigabitEthernet4/3
ip address X.X.X.X
ip nat outside
NO rate-limit input 45000000 5625000 11250000 conform-action transmit exceed-action drop
no rate-limit output 45000000 5625000 11250000 conform-action transmit exceed-action drop
no cdp enable
Marwan ALshawi Mon, 09/01/2008 - 04:31
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
use policing with policy map better
for example
acceess-lis 100 permit ip [source] [distnation]
class-map map1
match access-group 100
policy-map policy1
class map1
police 450000 conform-action transmit exceed-action drop
then apply it to the interface
like
interface [port number]
service-policy input policy1
good luck
if helpful Rate
Joseph W. Doherty Mon, 09/01/2008 - 05:24
What might be happening, your policier is allowing bursts. If your reduce your burst size (or interval), the policier will behave more like a physical interface for that data rate, although also acting like an interface with a small queue. If supported, you might consider using a shaper to regulate speed. As you reduce the burst size, it too behaves more like a physical interface for that data rate but it queues the excess instead of dropping it.
