Automatic recording of all incoming calls in UCCX 5.0
Answered Question
Sep 1st, 2008
I would like to know if there is a way to automatically record all incoming calls in UCCX 5.0?
Many Thanks
Correct Answer by matt.rossmeisl about 8 years 5 months ago
We have a customer using this method, and although I dont think Cisco supports it; it does work.
Is there a way of holding the recordings on the server longer than 7 days? I know if they are saved on CSD they will be held for 30 days but our customer would like this behavior for all recordings.
Correct Answer by Nicolas Mansour about 8 years 5 months ago
Hi there,
You can create a workflow to automatically record all calls. The draw back is that it will save it for 7 days or you will have to create a bulk batch to export them.
Correct Answer by ra_jeshkalra_2 about 8 years 5 months ago
I am using Witness,, which supports port spanning on the voice gateway side.. and can set a filter on the numbers,, to record calls as per your choice!!
Correct Answer by Chris Deren about 8 years 5 months ago
I would recommand 3rd party solution such as CallRex, NICE, Witness, Colabrio, etc
Chris
Overall Rating: 5 (4 ratings)
Correct Answer
Chris Deren Mon, 09/01/2008 - 06:38
Chris
Correct Answer
ra_jeshkalra_2 Mon, 09/01/2008 - 06:48
araffill Tue, 09/02/2008 - 00:37
Hi Chris and Rajesh,
Tx a lot for your helpful responses.
I will talk to my manager regarding purchasing the 3rd party solutions.
Correct Answer
Nicolas Mansour Wed, 09/03/2008 - 05:26
Hi there,
Correct Answer
matt.rossmeisl Tue, 09/23/2008 - 08:35
Nicolas Mansour Wed, 01/07/2009 - 09:15
Hi Matt,
By default, the CSD will hold on to the recording for 7 days unless it was extended manually for 30 days (doable only once).
The workaround is to create a script that will automatically export the recordings from UCCX to a specified folder. You can find the steps in the Cisco CAD Service Information under the section "Converting Recordings From *.raw to *.wav".
Enjoy
araffill Wed, 01/07/2009 - 02:52
Hi Nicolas,
Many Thanks for the helpful reply.
I went on a long break from work and missed to reply to your post before my holidays.
My apologies.
Will now start working on the script to automatically record the calls.
Wish you a great year ahead
Cheers.
