asdm image command not working on FWSM
Sep 1st, 2008
Hi all,
I m trying to enable ASDM on FWSM but the commands are not there to enable it.....
FWSM(config)# asdm ?
configure mode commands/options:
group Associate object group names with interfaces. Warning: This option
is designed for use solely by ASDM. Do not manually configure this
option.
history Enable/Disable Device Manager data sampling
location Associate an external network object with an interface. Warning:
This option is designed for use solely by ASDM. Do not manually
configure this option.
exec mode commands/options:
disconnect Specify ASDM session id to be disconnected after this keyword
FWSM(config)# asdm
Firewall(config)# asdm image disk0:/asdm.bin command is not seen on FWSM... need assistance for the same.. Here are some more information which can help you all in guiding me...
FWSM# dir flash:
Directory of flash:/
2 -rw- 5632060 <no date> asdm
1 -rw- 6037560 <no date> image
3 -rw- 4984 <no date> startup-config
No space information available
FWSM#
What i can see is in dir command its not showing date or the space available on flash. Is there any bug????
FWSM# sh version
FWSM Firewall Version 3.2(2)
Device Manager Version 5.2(1)F
Compiled on Thu 16-Aug-07 14:40 by dalecki
FWSM up 8 days 15 hours
failover cluster up 8 days 15 hours
Hardware: WS-SVC-FWM-1, 1024 MB RAM, CPU Pentium III 1000 MHz
Flash SMART CF @ 0xc321, 20MB
0: Int: Not licensed : irq 5
1: Int: Not licensed : irq 7
2: Int: Not licensed : irq 11
The Running Activation Key is not set, using default settings:
Licensed features for this platform:
Maximum Interfaces : 256
Inside Hosts : Unlimited
Failover : Active/Active
VPN-DES : Enabled
VPN-3DES-AES : Enabled
Cut-through Proxy : Enabled
Guards : Enabled
URL Filtering : Enabled
Security Contexts : 2
GTP/GPRS : Disabled
BGP Stub : Disabled
VPN Peers : Unlimited
Serial Number: SAD12140839
Running Activation Key: 0x00000000 0x00000000 0x00000000 0x00000000
Configuration last modified by enable_15 at 07:14:19.230 UTC Sun Aug 31 2008
FWSM#
--- Piyush
Overall Rating: 3 (2 ratings)
JORGE RODRIGUEZ Mon, 09/01/2008 - 08:55
  • Green, 3000 points or more
Piyush,
Is http enable?
if not try enabling
firewall(config)#http server enable
assuming you have configured inside interface and have ip connectivity to the fw allow inside host to access asdm
firewall(config)#http inside_ip mask
seems your asdm image is in flash, when you issue the above try from PC https://fw_ip_address
if it does not load
try
firewall(config)#asdm image ?
firewall(config)#asdm image flash:/image_name
then try again from pc https://fw_ip_address
http://www.cisco.com/en/US/docs/security/fwsm/fwsm32/asdm52f/release/notes/asdm521f.html
Let us know how it works out
Rgds
Jorge
piyush_singh Tue, 09/02/2008 - 05:25
Jorge,
My issue got resolved, thanks for your valuable time.. but was just worried why
asdm image command doesnt work on FWSM & also when i do a dir flash: i cannot find asdm version & file type or date...
FWSM#dir flash:
2 -rw- 5632060 asdm
1 -rw- 6037560 image
3 -rw- 4984 startup-config
FWSM#
& ya the commands which i used were:
http server enable
http A.B.C.D netmask Name of interface
---- Piyush
JORGE RODRIGUEZ Tue, 09/02/2008 - 06:11
Piyush, glad you resolved it, could you tell us how you fixed it?
Bst Rgds
Jorge
piyush_singh Tue, 09/02/2008 - 06:20
Jorge, it was just 2 commands which resolved the issue...
http server enable
& then you can try from your pc with url https://
but i m still stuck y the command asdm image is not working for FWSM & the files in flash are shown differently..
FWSM# dir flash:
2 -rw- 5632060 asdm
You can see in above output its showing no space information available for flash & not even the file types present in flash ie asdmxxx.bin
-- Piyush
JORGE RODRIGUEZ Tue, 09/02/2008 - 08:07
have you entered activattion keys yet? not that this could issue on files dates but worth a try since your first post seems no running activation keys, perhaps some other netpro could comment on this one..
Jorge
robertson.michael Tue, 09/02/2008 - 08:18
  • Silver, 250 points or more
Hi Piyush,
FWSM 3.2 does not use the 'asdm image' command because you can only have one version of ASDM loaded on the flash at a time. Thus, it would be redundant to specify the ASDM image name. This is why you must save the ASDM image file as "asdm" on the flash and this file is overwritten each time you load a new version onto the flash.
The same is true for FWSM image files. There is no 'boot system' command because you can only have one FWSM image loaded onto the flash at any given point in time (called "image").
-Mike
piyush_singh Mon, 10/06/2008 - 10:29
But still i m not able to see space information available onto FWSM flash
FWSM#dir flash:
2 -rw- 5632060 asdm
FWSM#
