VM to a Public Folder.
Answered Question
Sep 1st, 2008
Hi all,
I have a request to setup a Voicemail to go to a public folder? Is this possible?
Many Thanks
Anthony.
Correct Answer by tim.giles about 8 years 7 months ago
Yes, creating a distribution list is the easiest way to set this up.
Alternatively, create a mailbox in Exchange/AD and give these people permissions to access it.
Then from Outlook, add it as an additional mailbox (Tools > E-mail accounts > View or change existing e-mail accounts > change > more settings > advanced > "add") on each of their PC's and they can all view the same mailbox as a central store.
Details on distribution lists attached:
http://cisco.com/en/US/docs/voice_ip_comm/unity/403/administration/guide/ex/SAG_0180.html
Please rate useful posts....
Overall Rating: 5 (2 ratings)
Jaime Valencia Mon, 09/01/2008 - 07:37
  • Cisco Employee,
  • Hall of Fame,
    2011
more details??
unity?? CUC?? version??
exactly what do you mean by a public folder??
would be easier if you explain what you want to happen
please always provide those kind of details when posting
java
if this helps, please rate
Anthony O'Reilly Mon, 09/01/2008 - 08:10
Since Apologies for lack of information Java.
We are using Cisco Unity 4.0 Build 4.0(5)and we would like to configure a voicemail to go to an Exchange 2003 Public folder. This way staff that have access to this folder can listen to the voicemail.
Is this possible, I hope I have explained myself better here.
Anthony.
Jaime Valencia Mon, 09/01/2008 - 09:55
  • Cisco Employee,
  • Hall of Fame,
    2011
you can set a call handler to take the message and make the message recipient a distribution list of who should receive the VM
if they don't have a dedicated mailbox then configure just one and configure alternate extensions for that one
java
Correct Answer
tim.giles Wed, 09/03/2008 - 02:51
  • Silver, 250 points or more
