Sep 1st, 2008
I am receiving an OID alert in from some Cisco Metro 3750 switches. Summary of OID is On the MIB tree, I get as far as which is the OSPF tree but it only goes as far as 15 which is ospfConformance. Any ideas on how I can translate this OID?
Show ver
Metro_3750#sh ver
Cisco IOS Software, C3750ME Software (C3750ME-I5-M), Version 12.2(25)EY3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Fri 02-Sep-05 08:07 by myl
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750ME Boot Loader (C3750ME-HBOOT-M) Version 12.1(14r)AX, RELEASE SOFTWARE (fc1)
Metro_3750 uptime is 33 weeks, 3 days, 3 hours, 14 minutes
System restarted at 12:15:34 GMT Fri Jan 11 2008
System image file is "flash:c3750me-i5-mz.122-25.EY3/c3750me-i5-mz.122-25.EY3.bin"
cisco ME-C3750-24TE (PowerPC405) processor (revision E0) with 118784K/12280K bytes of memory.
Processor board ID CAT1010N11N
Last reset from power-on
1 Virtual Ethernet interface
24 FastEthernet interfaces
4 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
1024K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:17:5A:8D:63:80
Motherboard assembly number : 73-9938-04
Motherboard serial number : CAT10081ABN
Model revision number : E0
Motherboard revision number : A0
Model number : ME-C3750-24TE-M
Daughterboard assembly number : 73-9939-02
Daughterboard serial number : CAT10090AXK
Daughterboard revision number : A0
System serial number : CAT1010N11N
Top Assembly Part Number : 800-25952-04
Top Assembly Revision Number : B0
Version ID : V05
CLEI Code Number : COM1510ARA
Hardware Board Revision Number : 0x09
Switch Ports Model SW Version SW Image
* 1 28 ME-C3750-24TE 12.2(25)EY3 C3750ME-I5-M
Configuration register is 0xF
Joe Clarke Mon, 09/01/2008 - 11:45
I'd have to see the raw trap PDU to be sure, but I'm guessing this is your application's way of saying this is an OSPF trap of general type 6 (enterprise-specific) and specific type 10 which would be ospfTxRetransmit:
ospfRouterId, -- The originator of the trap
ospfNbrRtrId, -- Destination
STATUS current
"An ospfTxRetransmit trap signifies than an
OSPF packet has been retransmitted on a non-
virtual interface. All packets that may be re-
transmitted are associated with an LSDB entry.
The LS type, LS ID, and Router ID are used to
identify the LSDB entry."
::= { ospfTraps 10 }
maryodriscoll Tue, 09/02/2008 - 01:38
Ok, that is helpful. What we are receiving is the trap below. OspfTXRetransmits though -
should that be something I worry about as they are occuring very often(or rather the trap is logged often)?
SNMP config on the Metro Switch is as follows:
snmp-server enable traps ospf state-change
snmp-server enable traps ospf errors
snmp-server enable traps ospf retransmit
snmp-server enable traps ospf lsa
snmp-server enable traps ospf cisco-specific state-change
snmp-server enable traps ospf cisco-specific errors
snmp-server enable traps ospf cisco-specific retransmit
snmp-server enable traps ospf cisco-specific lsa
Node AlertKey Summary Manager LastOccurrence Count
Metro_3750 . 6 10 ov_nmsorcnnm02 02/09/08 10:24:39 439
