Does the ACE support DFP or something like the ACA algorithm
Answered Question
Sep 1st, 2008
Hi - I have a requirement to load balance traffic accross some servers where the load on each server cannot neccesarily be measured based on the number of connections to it. The ACA algorithm would have been useful for this, as would configuring DFP. I cannot see anything in the config guide that refers to DFP or a load balancing algorithm that takes load into consideration. Does anyone know if there any other ways to achieve what I need?
Many Thanks in advance
Dom
Correct Answer by Syed Iftekhar Ahmed about 8 years 4 months ago
DFP is not supported on ACE.
The ACE 2.0+ code support load balancing based on SNMP probes.
SNMP is definitley a better option then DFP (As DFP agents were not available for most of the apps).
Contact you Application Vendor to get the load related MIBs and you are good to go.
Syed Iftekhar Ahmed
Overall Rating: 5 (1 ratings)
Correct Answer
Syed Iftekhar Ahmed Mon, 09/01/2008 - 10:57
Syed Iftekhar Ahmed
d-fillmore Tue, 09/02/2008 - 01:59
That's great - many thanks
Is this something you have implemented? If so, which MIB variables did you find the most useful.
Cheers, Dom
Syed Iftekhar Ahmed Tue, 09/02/2008 - 04:24
Every Application's MIB for Application Load will be different. You will have to contact your application vendor to figure out the appropriate MIBs.
I haven't got a chance personally to implement it but have read about it. For details
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/ace/v3.00_A2/configuration/slb/guide/probe.html#wp1100334
Syed Iftekhar Ahmed
