Problem with isdn
Sep 1st, 2008
I have the problem with interconnection of the router cisco 2800 with the Fleet 77(inmarsat)by BRI port.
The router display error messages that I can not understand.
debug isdn error command returns the following error message:
*Jan 1 01:10:15.527: ISDN BR1/0 SERROR: L2_Go: at bailout DLCB is
L2: sapi 0 tei 65 ces 255 ev 0x0
*Jan 1 01:10:15.539: ISDN BR1/0 SERROR: L2_Go: at bailout DLCB is
By activating the debug isdn q921 I have the following message:
*Jan 1 01:13:35.471: ISDN BR1/0 Q921: User RX <- INFO sapi=0 tei=65, ns=31 nr=2
*Jan 1 01:13:36.143: ISDN BR1/0 Q921: User RX <- INFO sapi=0 tei=65, ns=32 nr=2
*Jan 1 01:13:36.155: ISDN BR1/0 Q921: User RX <- INFO sapi=0 tei=65, ns=33 nr=2
At wiring there is no problem, the BRI interface is well mounted and recognized:
R-2800#show interfaces brI 1/0
BRI1/0 is up, line protocol is up (spoofing)
Hardware is BRI
Description: **** Connexion France Telecom ****
Internet address will be negotiated using IPCP
MTU 1500 bytes, BW 128 Kbit, DLY 20000 usec,
Encapsulation PPP, loopback not set
Keepalive not set
Last input 00:00:00, output 01:24:47, output hang never
Last clearing of "show interface" counters 02:38:20
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/1/16 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 96 kilobits/sec
5618 packets input, 86817 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
18 packets output, 144 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 unknown protocol drops
3 carrier transitions
when I make a test call my error message below:
*Jan 1 03:24:03.219: ISDN BR1/0 **ERROR**: host_disconnect_ack: Unfound B-chann
el on Disconnect_Ack call id 0x8008
To help me below the configuration implemented on my router:
service password-encryption
hostname R-2800
enable secret 5 ********
ip subnet-zero
ip dhcp excluded-address ip_adress
ip dhcp excluded-address ip_address
ip dhcp pool Pool_DHCP
network ip_address 255.255.255.0
default-router ip_gateway
ip name-server 193.252.234.1
isdn switch-type vn3
interface GigabitEthernet0/0
ip address ip_gateway 255.255.255.0
no ip directed-broadcast
shutdown
interface BRI1/0
description **** Connexion France Telecom ****
bandwidth 128
ip address negotiated
ip nat outside
encapsulation ppp
no keepalive
dialer string "90667#"
dialer hold-queue 10
dialer-group 1
isdn tei-negotiation first-call
ppp authentication pap callin
ppp pap sent-username inmarsat password 7 000D1D0B054918071B
ip nat inside source list 1 interface BRI1/0 overload
no ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 BRI0
access-list 1 permit ip_address 0.0.0.255
dialer-list 1 protocol ip permit
line con 0
password Total2008
transport input none
stopbits 1
line vty 0 4
password ********
login
end
Thanks for your help
Giuseppe Larosa Mon, 09/01/2008 - 08:47
Hello Gatien,
a very useful command for ISDN is:
sh isdn status
it shows the L1, L2, L3 real status
the correct L2 state is MULTIPLE_FRAME_ESTABLISHED
post the output of sh isdn status
Hope to help
Giuseppe
pointenoire Mon, 09/01/2008 - 09:22
Thanks for you answer.
isdn statur ordering me back this:
Global ISDN Switchtype = vn3
ISDN BRI1/0 interface
dsl 8, interface ISDN Switchtype = vn3
Layer 1 Status:
ACTIVE
Layer 2 Status:
Layer 2 NOT Activated
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 8 CCBs = 0
The Free Channel Mask: 0x80000003
when I run the same command for a test call that ultimately fail (isdn test call ) I have this:
R-2800#sh isdn status
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 255, Ces = 1, SAPI = 0, State = ESTABLISH_AWAITING_TEI
Layer 3 Status:
CCB:callid=8003, sapi=0, ces=1, B-chan=1, calltype=DATA, hdlctype=HDLC-T
RUNK
Active dsl 8 CCBs = 1
The Free Channel Mask: 0x80000002
Giuseppe Larosa Mon, 09/01/2008 - 09:37
Hello Gatien,
the interface is stucked at L2 :
it is waiting for a TEI value to be assigned by the switch port.
If you can try to shut the BRI and after a while to reenable it.
If not enough if you can you need to reload the router.
use debug isdn q921 to see what happens during your attempts
Hope to help
Giuseppe
Richard Burts Mon, 09/01/2008 - 09:39
Gatien
Thank you for the additional information. When I saw in the first isdn status output that layer 2 was NOT Activated, then I thought that this was the problem. But then I remembered this line in your config:
which seems to indicate that it will not negotiate TEI until the first call. So the output of isdn status after attempting a call becomes the important one to look at. And it indicates:
I believe that this indicates some difficulty in negotiation between your router and the provider ISDN switch. Can you verify with your provider that the switch type is correct and whether there is any special setup required to communicate with their switch?
Rick
Giuseppe Larosa Mon, 09/01/2008 - 10:01
Hello Rick,
Actually Gatien is using a satellite device so the vn3 switch type could be wrong it is fine in France when connecting to France Telecom.
I would suggest to verify the switch type supported on the satellite receiver Fleet 77 BRI port
Hope to help
Giuseppe
Richard Burts Mon, 09/01/2008 - 10:35
Giuseppe
Thank you. Using satellite is a detail that I had not picked up. I believe that we both agree that the issue at this point is a failure to negotiate TEI with the switch.
Rick
pointenoire Mon, 09/01/2008 - 22:41
Hi all
Thank you for your suggestions.But I can not understand why I have this error permanently:
R-2800#debug isdn error
R-2800#ter mon
*Jan 1 04:25:47.094: ISDN BR1/0 SERROR: L2_Go: at bailout DLCB is NULL
L2: sapi 0 tei 66 ces 255 ev 0x1
*Jan 1 04:25:49.534: ISDN BR1/0 SERROR: L2_Go: at bailout DLCB is NULL
L2: sapi 0 tei 67 ces 255 ev 0x0
*Jan 1 04:25:49.550: ISDN BR1/0 SERROR: L2_Go: at bailout DLCB is NULL
And when I do tests of Appeal, I have this message:
Thanks for help
Giuseppe Larosa Tue, 09/02/2008 - 11:11
Hello Gatien,
the problem should be an ISDN switch type mismatch.
With the wrong switch type configured the BRI will try to use all possible TEI values: you see TEI 66 then TEI 67 but without any success.
When you use ISDN test command it fails because layer2 is not fine so no available B channel is found.
You need to find out what type of ISDN switch is the Fleet 77 BRI port and to configure the router port accordingly.
You may need to reload the router when changing ISDN switch type.
Hope to help
Giuseppe
pointenoire Wed, 09/03/2008 - 03:28
I close my provider inmarsat clear to me that the type of switch is isdn basic-net3, this change has not corrected the problem.
I still have the same error messages
Thanks for you help
adrienbomble Wed, 09/03/2008 - 07:15
I'm working with pointenoire.
The switch type was confirm as correct by the provider. => basic-net3
During deb isdn q921 we can see that Receiver Ready final (RRf) sapi messages are missing and don't know why.
*Jan 3 06:52:46.327: ISDN BR1/0 Q921: User RX <- RRp sapi=0 tei=64 nr=0
*Jan 3 06:52:46.599: ISDN BR1/0 Q921: User RX <- INFO sapi=0 tei=65, ns=81 nr=97
*Jan 3 06:52:47.363: ISDN BR1/0 Q921: User RX <- INFO sapi=0 tei=65, ns=82 nr=97
*Jan 3 06:52:47.379: ISDN BR1/0 Q921: User RX <- INFO sapi=0 tei=65, ns=83 nr=97
*Jan 3 06:52:47.391: ISDN BR1/0 Q921: User RX <- INFO sapi=0 tei=65, ns=84 nr=97
*Jan 3 06:52:47.595: ISDN BR1/0 Q921: User RX <- INFO sapi=0 tei=65, ns=85 nr=97
*Jan 3 06:52:48.587: ISDN BR1/0 Q921: User RX <- INFO sapi=0 tei=65, ns=86 nr=97
*Jan 3 06:52:49.583: ISDN BR1/0 Q921: User RX <- INFO sapi=0 tei=65, ns=87 nr=97
*Jan 3 06:52:52.447: ISDN BR1/0 Q921: User RX <- INFO sapi=0 tei=65, ns=88 nr=97
*Jan 3 06:52:52.467: ISDN BR1/0 Q921: User RX <- RR sapi=0 tei=65 nr=98
*Jan 3 06:52:53.559: ISDN BR1/0 Q921: User RX <- INFO sapi=0 tei=65, ns=89 nr=98
*Jan 3 06:52:54.551: ISDN BR1/0 Q921: User RX <- INFO sapi=0 tei=65, ns=90 nr=98
*Jan 3 06:52:56.379: ISDN BR1/0 Q921: User RX <- RRp sapi=0 tei=64 nr=0
*Jan 3 06:52:57.395: ISDN BR1/0 Q921: User RX <- INFO sapi=0 tei=65, ns=91 nr=98
*Jan 3 06:52:57.407: ISDN BR1/0 Q921: User RX <- INFO sapi=0 tei=65, ns=92 nr=98
*Jan 3 06:52:57.423: ISDN BR1/0 Q921: User RX <- INFO sapi=0 tei=65, ns=93 nr=98
*Jan 3 06:52:59.523: ISDN BR1/0 Q921: User RX <- INFO sapi=0 tei=65, ns=94 nr=98
*Jan 3 06:53:00.515: ISDN BR1/0 Q921: User RX <- INFO sapi=0 tei=65, ns=95 nr=98
*Jan 3 06:53:06.439: ISDN BR1/0 Q921: User RX <- RRp sapi=0 tei=64 nr=0
*Jan 3 06:53:07.427: ISDN BR1/0 Q921: User RX <- INFO sapi=0 tei=65, ns=96 nr=98
*Jan 3 06:53:07.439: ISDN BR1/0 Q921: User RX <- INFO sapi=0 tei=65, ns=97 nr=98
*Jan 3 06:53:07.455: ISDN BR1/0 Q921: User RX <- INFO sapi=0 tei=65, ns=98 nr=98
*Jan 3 06:53:07.475: ISDN BR1/0 Q921: User RX <- INFO sapi=0 tei=65, ns=99 nr=98
*Jan 3 06:53:10.455: ISDN BR1/0 Q921: User RX <- INFO sapi=0 tei=65, ns=100 nr=98
*Jan 3 06:53:11.451: ISDN BR1/0 Q921: User RX <- INFO sapi=0 tei=65, ns=101 nr=98
*Jan 3 06:53:13.439: ISDN BR1/0 Q921: User RX <- INFO sapi=0 tei=65, ns=102 nr=98
Giuseppe Larosa Wed, 09/03/2008 - 12:07
Hello Adrien,
have you reloaded the router after changing the isdn switch type ?
I'm afraid it is a necessary step.
Hope to help
Giuseppe
