IPCC 4.0(4) build 140 need to reset to factory default without reinstalling
I have IPCC 4.0(4) installed and everything is working however, i want to restore it to the factory default where i have to setup to enter the Licens info and LDAP info. I want to clear all current configuration.
I have tried the process of changing the ccndir.ini to old.ccndir.ini but i cannot find the com.cisco.wf.admin.install that should be located in the appadmin.properties file. All documentation that i read tells me that the appadmin.properties file is located in C:/program files/wfavvid but mine is located in C:/program files/wfavvid/properties so i am assuming that i have the correct appadmin.proterties file. Thanks in advance.
irisrios Fri, 09/05/2008 - 13:39
  • Silver, 250 points or more
