vpn on router
Sep 1st, 2008
i need on configuring remote-access vpn on a 2800 series router with authentication using acs..
cisco config link or guidliness would be appreciated.
Overall Rating: 5 (1 ratings)
Amin Shaikh Tue, 09/02/2008 - 05:01
I need config which support Microsoft VPN Client ...
the attached link is for Cisco VPN Client
Kindly help.
Amin Shaikh Tue, 09/02/2008 - 23:47
Thanks ; very helpful link.
Does the folllowing lines means that initially the authentication would be ACS-Server and incase ACS-Server is down then it would router-local username/password
aaa authentication ppp default group radius local
aaa authentication login default local
