multiple MAC addresses on a switchport
Sep 1st, 2008
  • Silver, 250 points or more
I have a pair of Checkpoint NGx R65
running in ClusterXL Active/Active
Unicast mode.
Eth0 of FW1 is connect to Catalyst switch SW1 6513 port 7/7 and Eth0 of FW2
is connected to Catalyst switch SW2 6513 port 7/8. There is an EtherChannel
trunk between these two switches.
When I connect to SW1 and run "show cam dynamic 7/7" I see this:
CAT6513-1> sh cam dynamic 7/7
* = Static Entry. + = Permanent Entry. # = System Entry. R = Router Entry.
X = Port Security Entry $ = Dot1x Security Entry M = Mac-Auth-Bypass Entry
Destination Ports or
VLAN Dest MAC/Route Des [CoS] Age VCs / [Protocol Type]
199 00-15-17-79-12-c6 0 7/7 [ALL]
199 00-d0-fe-8e-40-03 0 7/7 [ALL]
199 00-00-00-00-fe-00 0 7/7 [ALL]
199 00-d0-fe-8e-64-03 0 7/7 [ALL]
Total Matching CAM Entries Displayed = 4
CAT6513>
00-15-17-79-12-c6 = Firewall #1 physical MAC address
00-d0-fe-8e-40-03 = Cisco MAC address (no idea where it comes from)
00-00-00-00-fe-00 = Firewall #1 ClusterXL MAC address
00-d0-fe-8e-64-03 = Cisco MAC address (no idea where it comes from)
can someone tell me where the other Cisco
MAC addresses come from? I could not
find those mac addresses anywhere on the
switchports on both switches.
Thanks in advance.
Giuseppe Larosa Mon, 09/01/2008 - 23:07
  • Hall of Fame,
    Founding Member
Hello David,
I would look at the other Catalyst CAT6513-2 they send out some L2 multicast frames for CDP, VTP and so on. In sending these frames they use their own MAC addresses as source.
verify with a sh module if 00-d0-fe-8e-40-03 and 00-d0-fe-8e-64-03 are in the MAC address block of device CAT6513-2
Hope to help
Giuseppe
cisco24x7 Tue, 09/02/2008 - 03:11
Thank you guys. I will check. Andrew, yes, they are connected by fibre.
If I replace the Checkpoint NGx R65 firewalls
with Checkpoint NG with Application Intelligence
R55 firewalls, I will NOT see those MAC
addresses on the switchport. Why?
Giuseppe Larosa Tue, 09/02/2008 - 09:42
  • Hall of Fame,
    Founding Member
Hello David,
probably they have a different behaviour on L2 traffic.
If you can, try to use SPAN to capture the traffic and you will see what kind of frames have source MAC address the ones you see on switch.
What is strange is that the Astral should be in the middle so you should always see its frames !
Hope to help
Giuseppe
