Jon Marshall Mon, 09/01/2008 - 17:07
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
You simply need to copy the config to a tftp server and they will appear in clear text.
Use the "write net :"filename" command.
Jon
stephen.stack Tue, 09/02/2008 - 04:58
  • Silver, 250 points or more
hi
try this at the command prompt.
more system:running-config
Cheers
Stephen
jason.edelman Tue, 09/02/2008 - 11:58
I actually saw both of these options listed under the 7.x code, but wasn't sure about 6.3.
I don't have the boxes handy to test them, so I will have to wait and see.
Are you sure they work for PIX 6.3?
Jason
Jon Marshall Tue, 09/02/2008 - 13:27
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Jason
Saving the config to a tftp server definitely works for 6.3 code as i used to do it all the time.
The other command looks like a 7.x command to me so i can't say for sure.
Jon
