VPN Client 5.0.03 Issue on XP workstation
Sep 1st, 2008
We are having some problem with the Cisco VPN client 5.0.03 on a windows XP workstation, When try to connect with the client, getting an error message " ERROR: CISCO VPN CONNECTION TERMINATED LOCALY BY CLIENT, REASON 440 DRIVER FAILURE" What is the reason for this? Really appreciate some help.
JORGE RODRIGUEZ Mon, 09/01/2008 - 18:59
  • Green, 3000 points or more
Couple of things you may want to try,.
first try the procedure on xp
Error 440: Driver Failure
Usually related to Deterministic Network Enhancer
DNE suggestion - you can manually add the service to the local area connection.
Control Panel - Network and Internet
- Open Network and Sharing Center
- Open Manage Network Connection
- Right click on the Local Area Connection
- Select Install
- Select Service
- Select Have Disk
- Select browse and browse to c:\program files\common\Deterministic Networks\DNE\dne2000
- Select Open
http://forums.microsoft.com/TechNet/ShowPost.aspx?PostID=2077694&SiteID=17
seems this message is driver related, type reason 440 bellow this link some times output of these messages helps in giving clues of the issue
http://www.cisco.com/en/US/products/sw/secursw/ps2308/products_tech_note09186a00801f253d.shtml#topic1
Reason 440: Cannot start the driver. Make sure DNE is installed correctly. Make sure that _cvpndrva_ is installed correctly.
Description or Action:
Ensure that the DNE driver is loaded. Go to command prompt and type _net stop dne_. It should not be able to be stopped. However, if it cannot be found, then it is not installed. If installed, try _net stop cvpndrva_ and _net start cvpndrva_. This can't be done via service manager.
Note: Do not type the _ character when you enter these commands.
If above does not fix the issue, try un-installing and re-install the vpn client again, see if that resolve the problem, post results.
PLS rate any helpful post if it helps
Rgds
Jorge
