Does 3GE-GBIC-SC in 12000 suppoert q in q?
Sep 1st, 2008
Hi All,
i am using Cisco 12000 router with 3GE-GBIC-SC module on the same. Since I am unable to do dot1q in dot1q, can any one suggest me if this module support this feature or not?
Thanks and Regards
Mangesh A. Bhende
Giuseppe Larosa Mon, 09/01/2008 - 22:26
  • Hall of Fame,
    Founding Member
Hello Mangesh,
as per feature navigator Q in Q is not supported on GSR
http://www.cisco.com/go/fn
I made a search by platform using 12000 PRP and I've found just 802.1Q support (1 tag)
This confirms my experience with GSR.
I would suggest for L2 transport to investigate EoMPLS that is supported on 3GE engine 2 linecard I did extensive tests on this.
In this way you should be able to transport QinQ frames over MPLS.
Hope to help
Giuseppe
bhende.mangesh Mon, 09/01/2008 - 22:31
Hi Giuseppe,
thank you very much and even i too think so.
Thanks and regards
Mangesh A. Bhende
