Security configuration failed
Sep 1st, 2008
during installation of the CUCM 6 on a
VMware server
I get an error.
Security configuration failed (1)
I have changed passwords tried many diffrent combinations am not able to
move forward can someone help me fix this problem. Thanks
gogasca Tue, 09/02/2008 - 07:24
Adding a subscriber? or new Publisher?
Make sure Network information / cable is accurate and everything is reachable. Secuirty passwords must be in synched...
Or speak with your cisco AM so he can forward you an already installed VMware image.
Seroj Hacopian Tue, 09/02/2008 - 08:32
thanks for the reply,
this is a publisher and it's the first node
on the network and the only CUCM 6.
thanks
andrew.riley Sat, 10/04/2008 - 21:30
I had the same issue with 6.0.1 in vmware 2.0
would fail on the secuity check step and reask for the password..could replicate everytime without file.
found that it only passed when I set the install to use an NTP server and the NTP was available..
once the NTP was set it went through no problems..
** interesting point though.. on the same box cucm 7.0 worked fine with no NTP.. they must have fixed something..
