Load Balancing
Sep 1st, 2008
We have two ASA5550's, ver. 7.1(2). We setup Load Balancing, using virtual cluster IP address. The primary ASA is setup with priority 10. The secondary ASA is setup with priority of 8. When the first client (VPN client) connects, the client connects to the Secondary ASA. When the second client connects, it also connects to the Secondary ASA. Is there a way to setup Active/Active? So, when the first client (VPN client) connects, it will connect to the Primary. When the second client connects, it will connect to the Secondary. When the third client connects, it will connect to the Primary and so on.
Thanks.
Diane
Overall Rating: 5 (1 ratings)
dianewalker Tue, 09/02/2008 - 06:55
Thanks very much for your prompt response. Attached are the files for your information.
I put the show failover and show vpn load-balancing on the same file (primaryshbl.rtf).
Thanks.
Diane
