LMS 3.0.1 Errors when synching configs
Sep 1st, 2008
HTTP Status 500 -
type Exception report
message
description The server encountered an internal error () that prevented it from fulfilling this request.
exception
java.lang.NullPointerException
com.cisco.nm.rmeng.dcma.ui.helper.DCMAJobUIUtil.isJBPEnabled(DCMAJobUIUtil.java:893)
com.cisco.nm.rmeng.dcma.ui.helper.DCMAJobUIUtil.scheduleJob(DCMAJobUIUtil.java:263)
com.cisco.nm.rmeng.dcma.ui.action.UpdateArchiveAction.perform(UpdateArchiveAction.java:324)
org.apache.struts.action.ActionServlet.processActionPerform(ActionServlet.java:1786)
org.apache.struts.action.ActionServlet.process(ActionServlet.java:1585)
org.apache.struts.action.ActionServlet.doGet(ActionServlet.java:491)
javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
javax.servlet.http.HttpServlet.service(HttpServlet.java:802)
com.cisco.nm.cmf.util.AccessLogFilter.doFilter(Unknown Source)
note The full stack trace of the root cause is available in the Apache Tomcat/5.5.17 logs.
kmmehlkmmehl Mon, 09/01/2008 - 23:37
also with "edit config"
HTTP Status 500 -
message
exception
com.cisco.nm.rmeng.config.cfgedit.ui.action.CfgEditOpenConfigAction.perform(Unknown Source)
