NTP on 3750 Switch
Sep 2nd, 2008
Hi Guys, I'm trying to set my 3750 switch as an NTP server so that the surrounding network devices take time from it. I notice though when i add the 3750 as an NTP server on another switch, it does not sync although they are directly connected.
How do i verify that my 3750 is capable of pulling time from the internet, then serving as a host? (it doesnt support the NTP master command - although i will not use it)
this is my switch version outpu:
Cisco IOS Software, C3750 Software (C3750-IPSERVICES-M), Version 12.2(25)SEE2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Fri 28-Jul-06 08:46 by yenanh
Image text-base: 0x00003000, data-base: 0x010CE290
satish_zanjurne Tue, 09/02/2008 - 01:32
Hi See configuration below..
*****For the Client*****
clock timezone EST -5 ????
ntp source loopback 0 ?????
ntp server ip_address key 1
!--- For the server:
clock summer-time EDT recurring 1 Sun Apr 3:00 last Sun Oct 3:00
clock calendar-valid
ntp source loopback0
ntp update-calendar
!--- This sends NTP broadcast packets.
ntp broadcast client
!--- This receives NTP broadcast packets.
jtphilies Tue, 09/02/2008 - 16:55
Hi Satish, thanks for your response. but half of those commands are not supported on my Switch.
wangyb Tue, 09/02/2008 - 22:31
You can verify the ntp is configurated successfully through the 'show ntp sta'..
for example:
DWTL_7F_3560#show ntp status
Clock is synchronized, stratum 4, reference is
nominal freq is 119.2092 Hz, actual freq is 119.2087 Hz, precision is 2**18
reference time is CC68AC26.75F29A0E (14:24:38.460 BeiJing Wed Sep 3 2008)
clock offset is 5.2167 msec, root delay is 290.73 msec
root dispersion is 106.69 msec, peer dispersion is 11.32 msec
DWTL_7F_3560#show clock
14:25:22.872 BeiJing Wed Sep 3 2008
jtphilies Tue, 09/02/2008 - 23:30
Thank your Wangyb, i am aware of those commands. My 3750 is currently sycing time.
But when i config my 3560 to use the 3750 as the ntp server it does not sync when i do a #sh ntp ass
