Cross server login
Answered Question
Sep 2nd, 2008
during cross server login while transferring we get 'one moment please' in US english- we want that in UK English. How do I find that prompt, I thought there used to be text files in the commserver conversation directories explaining each prompt but I can't find this. I've attached a port status shot of this - which is the actual prompt I need to change and where can I get a UK version of it?
Correct Answer by ranpierce about 8 years 7 months ago
anyone have the UK prompts and can send the one that Jaginder needs.
Hope this helps. Randy
Overall Rating: 5 (1 ratings)
ranpierce Tue, 09/02/2008 - 08:53
  • Silver, 250 points or more
Hi the prompts are in \CommServer\Localize\Prompts\ and the file explaining each promt is called promts.ini and is in seperate folders under that directory. You will find them. Open promts.ini with notepad.
Hope this helps.
If you only have enu directory then you do not have UK installed.
Randy
askq2forum Wed, 09/03/2008 - 02:01
Randy thanks for the reply, I have ENG file loaded and within the avhandoff we have the file but its obviously US not ENG.
Correct Answer
ranpierce Wed, 09/03/2008 - 11:18
askq2forum Wed, 09/03/2008 - 12:08
Randy thanks for your help, if nobody posts the UK version I will request from TAC.
