Callmanager Service crashes
kbehymerisg Tue, 10/14/2008 - 08:23
I have the same problem. Was your problem fixed with a new license file?
allan.thomas Tue, 10/14/2008 - 11:03
Please refer to the following URL, particularly the POST install checks:-
It is important that you obtain the software feature license otherwise the callmanager service will not start.
The following information is taken from the 6.1.2 Release notes:-
Cisco CallManager Service Stops After Upgrade to Cisco Unified Communications Manager 6.X
After you upgrade to Cisco Unified Communications Manager 6.X from a compatible Cisco Unified CM 5.X release, the Cisco CallManager service does not automatically run, even though Cisco Unified Serviceability shows that the Cisco CallManager service is activated.
Immediately after you complete the upgrade, upload the software feature license that is required for Cisco Unified Communications Manager 6.X in Cisco Unified Communications Manager Administration, and restart the Cisco CallManager service in Cisco Unified Serviceability. Until you perform these tasks, devices fail to register with Cisco Unified Communications Manager.
For more information on licensing, refer to the licensing chapters in the Cisco Unified Communications Manager Administration Guide and the Cisco Unified Communications Manager System Guide.
brandon00 Thu, 12/18/2008 - 10:46
I have this same problem. Only I initiated a switch versions from 6.1.2 to 6.1.1 and now when 6.1.1 comes up it gives me this error NoFeatureLicense. When I switch back to 6.1.2 everything works fine. Since I'm going back to 6.1.1 why do I get this error if 6.1.2 can see the licsense just fine?
