satish_zanjurne Tue, 09/02/2008 - 03:37
I am not aware of actual command , but other way could be :)
"See the logs generated while module was removed & re-inserted if the logs shows timestamp, comapre the current switch time & log timestamp "
HTH..rate if helpful
andrew.burns Tue, 09/02/2008 - 04:02
You can use this command:
show diagnostic events
After initial booting of the switch you should get an entry every time a module initialises.
Andrew.
