Upgrade IOS, tftp-DHCP
Sep 2nd, 2008
I have 1500 new 2960 switches, and want to upgrade image.
Do it manually seems time consuming, so I looked at Ciscos website to do this with DHCP on bootup. It gets the IP, tftp and start to download the image, then it stops. I have tried to set the hex value but still got problems.
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_44_se/configuration/guide/swipaddr.html#wp1184895
This is my config.
ip dhcp pool dhcp
network 192.168.1.0 255.255.255.0
bootfile c2960-lanbase-tar.122-44.SE2.tar
default-router 192.168.1.1
option 150 ip 192.168.1.1
interface Vlan1
no ip route-cache
ip http server
tftp-server flash:c2960-lanbase-tar.122-44.SE2.tar
tftp-server flash:config-boot.text
And this is my result:
00:01:17: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to up
00:01:28: AUTOINSTALL: Vlan1 is assigned 192.168.1.2
00:01:28: AUTOINSTALL: Obtain tftp server address (opt 150) 192.168.1.1
00:01:28: AUTOINSTALL: Obtain default router (opt 3) 192.168.1.1
Loading c2960-lanbase-tar.122-44.SE2.tar from 192.168.1.1 (via Vlan1): !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
[OK - 9953280 bytes]
c2960-lanbase-mz.122-44.SE2/
% Invalid input detected at '^' marker.
00:02:56: %PARSER-4-BADCFG: Unexpected end of configuration file.
00:02:56: %SYS-5-CONFIG_I: Configured from tftp://192.168.1.1/c2960-lanbase-tar.122-44.SE2.tar by console
It looks like it downloads the image from tftp, but then it says invalid input.
Is there someone who has done this.
Lamin
Giuseppe Larosa Tue, 09/02/2008 - 11:34
  • Hall of Fame,
    Founding Member
Hello Lamin,
I've never done this, however from the message above I think the client switch has taken the tar file for the config file.
the example in your reference is different:
Switch# config terminal
Switch(config)# ip dhcp pool pool1
Switch(dhcp-config)# network 10.10.10.0 255.255.255.0
Switch(dhcp-config)# bootfile config-boot.text
Switch(dhcp-config)# default-router 10.10.10.1
Switch(dhcp-config)# option 150 10.10.10.1
Switch(dhcp-config)# option 125 hex
0000.0009.0a05.08661.7574.6f69.6e73.7461.6c6c.5f64.686370
Switch(dhcp-config)# exit
So first the client switch has to load a config file and later it will download the image.
Note:
Before following the steps in this table, you must create a text file (for example, autoinstall_dhcp) that will be uploaded to the switch. In the text file, put the name of the image that you want to download (for example, c37502970-ipservices-mz.122-44.3.SE.tar). This image must be a tar and not a bin file.
then the client switch can do:
This example uses a Layer 3 SVI interface on VLAN 99 to enable DHCP-based autoconfiguration with a saved configuration:
Switch# configure terminal
Switch(conf)# boot host dhcp
Switch(conf)# boot host retry timeout 300
Switch(conf)# banner config-save ^C Caution - Saving Configuration File to NVRAM May Cause
You to Nolonger Automatically Download Configuration Files at Reboot^C
Switch(config)# vlan 99
Switch(config-vlan)# interface vlan 99
Switch(config-if)# no shutdown
Switch(config-if)# end
Hope to help
Giuseppe
lamin.sonko Thu, 09/11/2008 - 05:44
I found out from TAC that this is not supported on my IOS version 122-35.SE5
TAC
"- I want to tell you that dhcp auto image upgrade is available in 12.2(44) onwards"
/Lamin
