Trace an IP address on the LAN
Sep 2nd, 2008
I have some switchs Cisco and I would like to find an IP address on the LAN.
I want trace and IP address or a MAC address
I would like to find the out-port of the switch where the computer is connected.
I know I can use the command sh mac addr dyn | inc <mac address> and after fnd the next switch with the cdp but it's long.
Can I find an automatic solution?
Or an other solution ?
Thank you for your help.
branfarm1 Tue, 09/02/2008 - 04:27
There are quite a few switch port mapping programs out there. Some even have free versions, like this one from ManageEngine: http://manageengine.adventnet.com/products/oputils/switch-port-mapper.html
I use the Solarwinds Engineer's toolset, which has a nice switchport mapper, but the set will cost you some $$.
You can try searching the opensource community -- they might have a free mapper out there.
hth
