ASA 5505 system image problem
Sep 2nd, 2008
ASA system flash was ereased, so the device reboot on rommon mode, i loaded the system image to the device and it worked but the problem is when i try to reload the device, it boot on remmon mode again, after i did a "show ver" command it apeares "System image file is "tftp://192.168.1.1/asa723-k8.bin", will i try to copy tftp server to flash, it shows this message:"%Error opening tftp://192.168.1.1/asa723-k8 (No such device)"
Marwan ALshawi Tue, 09/02/2008 - 04:30
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
make sure u have ip connectivity with 192.168.1.1
u can ping it and also if it windows make sure no personal firewall blocking the traffic
and make sure u write th file name right
including .bin
good luck
