Cisco Catalyst 1900
Sep 2nd, 2008
Can anyone tell me if I can use the Catalyst 1900s for a home lab. I am taking the CCNA and have access to 2 of them for free. Problem is , I believe the ios is version 9. If they are useable, is there an upgrade image out there anywhere?
glen.grant Tue, 09/02/2008 - 05:53
They are not a good option as the command line is different than current IOS offerings. If possible dig up a 2950 switch.
phyllomeds Tue, 09/02/2008 - 06:01
Thanks. I appreciate your input. They were laying around my office and I was unsure if they had any use at all.
Giuseppe Larosa Tue, 09/02/2008 - 09:49
Hello David,
1900 actually have a firmware that comes in two versions:
standard edition: a text menu based interface
enterprise edition: can have an IOS like CLI and can use AAA like TACACS+ for authentication but they are different then modern switch : no voice vlan concept for example, also show commands are limited and with different output.
A c2950 would be better, if with enterprise edition you can use them as second switch.
Only possible upgrade is to 9.0.7 or like they are old systems.
Hope to help
