ACE probe dilemma
Sep 2nd, 2008
Hi, I have a requirement to use the ACE to provide Active/Standby service for 2 services located on 2 physical servers. Server A is active for one port and backup for antoher, Server B vice versa.
As well as this, I am doing port translation - incoming requests to one port are being translated to one of two ports - see config below
rserver host TEST-FE01
ip address 10.100.100.1
inservice
rserver host TEST-FE02
ip address 10.100.100.2
inservice
serverfarm host test-farm
predictor leastconns
rserver TEST-FE01 20902
backup-rserver TEST-FE02 20902
inservice
rserver TEST-FE01 20903
inservice standby
inservice standby
rserver TEST-FE02 20903
backup-rserver TEST-FE01 20903
inservice
My problem is that I want to configure probes for each ip/port combination, but I can't seem to achieve this as my server farm contains servers that listen on more than one port and a probe can only be configured with one TCP port and can only be applied to either the rserver or the whole serverfarm.
Can anynone see how I can achieve this
Many Thanks in advance
Overall Rating: 5 (1 ratings)
Syed Iftekhar Ahmed Tue, 09/02/2008 - 09:37
You will need to define probe under serverfarms's Rserver config
probe tcp port-20902
port 20902
probe tcp port-20903
port 20903
inservice
inservice
probe port-20902
inservice
probe port-20903
inservice
Syed
d-fillmore Mon, 09/08/2008 - 00:19
Many Thanks again Syed.
For some reason I thought I could only have one probe per serverfarm :S
