[Question] CCMUser on Call Manager 4.1(3) SR7
Sep 2nd, 2008
Hi all,
is there anywere on the Call Manager a Logfile that stores Call Forward Changes that are made via the CCMUser Webpage?
We have tried to find these on our system searching on the Publisher for a Number Combination that we had added as a Call Forward Destination.
Best regards
Steffen
Chris Deren Tue, 09/02/2008 - 06:15
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
I doubt there are any logs that will show it. This change is done directly in CM Pub (CM 6.0 and below) and local subscriber db in CM 6.1 + (and replicated out to Pub).
Chris
Steffen.Baier Tue, 09/02/2008 - 06:17
Shame,
we kind of need to proove to the customer that a user had "forgotten" to activate a call forward.
Unfortunately do we not log unaswered calls at present so the calls logs are of no use.
THX
Steffen
Jaime Valencia Tue, 09/02/2008 - 06:36
  • Cisco Employee,
  • Hall of Fame,
    2011
that could only be buried within the iis logs but you would need to look at the whole url string and see if it shows up in there
java
if this helps, please rate
