Unable to access switch via ssh on C2950
Sep 2nd, 2008
Hi, I have configure the line for ssh:
conf t
line vty 0 15
transport input ssh
When I try to access the switch, I'm refuse.
I do see the option for SSH on the switch, just can't connect via SSH.
version running:
satish_zanjurne Tue, 09/02/2008 - 06:11
This version of IOS/Image supports SSH v1 & 2
Hope you have generated the SSH Key on switch using following commands.
hostname XYZ
ip domain-name ""
crypto key generate rsa
ip ssh timeout ""
ip ssh authentication-retries ""
use show ip ssh
show ssh
for verification.
glen.grant Tue, 09/02/2008 - 07:34
It almost sounds like you are still trying to telnet to the switch. What SSH client are you using to access the switch ? Putty , Tera Term SSH etc... Check to see if the key was configured, "show crypto key my rsa" , and it will show the key.
