Layer 3 point to point links
Answered Question
Sep 2nd, 2008
I have a design question. I am in the middle of restructuring our network using a routed access layer design. I am using a 10.0.0.0 /16 for each building i have, then a /24 for individual vlans within that building and advertising a /8 to my core. This is kind of a basic question i should probably know, but what is the best structure and practice for point to point routed links? Should they be in the same subnet as my /16 that i advertise to the distribution block or should i just use an entirely different IP with a /30?
For example, I have a building called "Building 5". It's summarized subnet would be 10.5.0.0 /16. I have a few vlans such as vlan 100 (10.5.100.0) and vlan 200 (10.5.200.0) Could my P2P links be 10.5.1.1 and on the distribution be 10.0.5.1.2 /30? or should i use something completely differentlike 192.168.1.0 /30?
Correct Answer by Collin Clark about 8 years 5 months ago
Mine is still in the 10 network (along with server and client subnets), but it's way outside the normal ranges. I like to start at the high end and work my way down. For example my first subnets would be-
10.255.255.0 /30
10.255.255.4 /30
10.255.255.8 /30
Different classes would be effective too.
Overall Rating: 4 (1 ratings)
Collin Clark Tue, 09/02/2008 - 07:18
I use a separate address space with /30 masks. When you traceroute, it's easy to spot "transit" links.
Hope that helps.
cowetacoit Tue, 09/02/2008 - 07:19
I just edited my message....
So you think a probably a 192 or 172 private address would be easier to spot? I see your point.
Correct Answer
Collin Clark Tue, 09/02/2008 - 07:33
10.255.255.0 /30
10.255.255.4 /30
10.255.255.8 /30
cowetacoit Tue, 09/02/2008 - 07:36
I like your design better than using a different class. Thanks for clearing that up.
