CME trunk to Callmanager
Hi All,
I have a customer that has 2 clusters, one CME cluster and one CUCM 6.1 cluster. They do NOT plan to migrate the CME users across to CUCM.
What is the easiest trunk to setup that will allow CME users to call CUCM users and vice versa??
Would be great if there are detailed instructions or examples on how to do this.
I have spent a lot of time on this already but i'm new to this so would appreciated anyone's help.
Cheers,
Hunt
Overall Rating: 5 (1 ratings)
gogasca Tue, 09/02/2008 - 08:33
  • Green, 3000 points or more
Hi Hunt,
Correct, under CCMAdmin, configure H.323 GW in CUCM using CME IP addr.
Correct regular...dial-peer
marymaynard Tue, 09/02/2008 - 10:44
If I can ask a related question, on the CME router...do I need to add separate dial peer stements for each one of the CUCM IP addresses for each member of the cluster if I want redundancy?
Thanks, Mary
marymaynard Tue, 09/02/2008 - 10:58
Thanks, Mary
gogasca Tue, 09/02/2008 - 11:03
yes.
Preference command will be needed
olighec Wed, 09/03/2008 - 10:07
I am going to be setting up a trunk between my Callmanager 6 and a CME 4.0 at a remote office. I currently use MGCP for all of my PSTN connections at this location. Will using H.323 for the trunk to the CME and MGCP for the trunks to PSTN cause problems? I couldn't really gather a straight answer from the document provided.
Chris
