question about "compare version"
Sep 2nd, 2008
My question is about "compare version", if I did third times change on a device in the short time(like 1 m), I will get three versions. Could I get only one version through LMS settings?
Thanks a lot!
Joe Clarke Tue, 09/02/2008 - 09:14
If you disable syslog message processing for config fetch under RME > Tools > Syslog > Automated Actions, then RME will not fetch the config update in real time. Instead, the changes will be captured when RME does its periodic polling or config fetch.
