DMA fails as CDR export fails
I am trying to do a DMA backup, but it fails due to CDR. I do not need CDR, I tried disabling the services and from the service parameters but DMA still fails...
I am not able to do a CDR export from the CAR tool...I tried purging all records from the CDR db.
any ideas,
Joel
error log:
[05:15:12 AM] Beginning CAR backup
[05:15:13 AM] Backing up CAR databases.
[05:15:13 AM] This can take a long time, depending on the size of the databases. Be patient.
[05:15:13 AM] Failure, CAR Export
05:15:13 AM] Failed to back up exportable format of CAR databases.
[05:15:13 AM] Backing up CAR reports.
05:15:13 AM] This can take a long time, depending on the size of the reports. Be patient.
[05:15:13 AM] Exportable format of CAR reports backed up successfully.
[05:15:13 AM] Could not backup CAR successfully on .
[05:15:14 AM] Backup information file(s) not saved, due to unsuccessful backup.
[05:15:15 AM] DMA backup process is completed.
[05:15:15 AM] The results are : Backup - Failed. Validation - Failed.
Jaime Valencia Tue, 09/02/2008 - 09:45
first of all you need to mention the version you have and the version to which you want to go
CDR and ART DB are not the same, so if you only purged the CDR DB try purging the CAR DB.
java
if this helps, please rate
I think it was either because I was on RDP or because of CSA.
When I switched to VNC and also disabled CSA, it now passes the CDR phase and creates the TAR file.
It fails when validating the file...
thanks for any help...
[05:28:20 AM] Failure, IDS SDK Installation
[05:28:50 AM] modExportDatabase=Failure
[05:28:50 AM] Could not complete database processing successfully.
[05:28:50 AM] Failed to verify Cisco CallManager database and directory backed up data.
[05:28:50 AM] The database and/or directory cannot be migrated as they are.
[05:28:50 AM] Correct the database and/or directory information and run DMA again.
[05:28:50 AM] Verification of DB in IDS failed. Retaining the TAR file as it is.
[05:28:50 AM] DMA backup process is completed.
[05:28:50 AM] The results are : Backup - Successful. Validation - Failed.
