message not identified
Sep 2nd, 2008
i receive the follow message in customer with c6509 and sup720: "RELIABILITY DRIVER: wrong signature on NVFLASH", somebody knows what it can be?
alex-pavezi Wed, 09/03/2008 - 09:37
I suggested the solution it customer and when it will have the reply I will go to postar for you. thaks.
engineerangelo Fri, 11/21/2008 - 02:12
I'm also experiencing the same message appearing and I have seen the details of the bug and its workaround. Unfortunately, the workaround doesn't work. The message is still there. After copying the image contained in the sup-bootflash to disk0, formatting it, and copying it back again, the message still appears.
Did I get the process right?
