vlan up/down
Sep 2nd, 2008
hi all,
i have alert that shows
sh int vlan6
Vlan6 is up, line protocol is down
Hardware is EtherSVI, address is 0017.95ab.1130 (bia 0017.95ab.1130)
Description: ProSoft_MAS
Internet address is 172.29.12.1/24
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Last input 00:21:37, output never, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 2
Queueing strategy: fifo
Output queue: 0/40 (size/max)
3553043 packets input, 356607841 bytes, 0 no buffer
Received 10719 broadcasts, 0 runts, 0 giants, 0 throttles
4417091 packets output, 297003733 bytes, 0 underruns
0 output errors, 1 interface resets
copchgasr4#sh vlan-switch
VLAN Name Status Ports
1 default active
5 SCADA_LAN active Fa1/1
6 Prosoft active Fa1/2, Fa1/3, Fa1/4, Fa1/5, Fa1/6, Fa1/7, Fa1/8, Fa1/9, Fa1/10, Fa1/11, Fa1/12, Fa1/13, Fa1/14, Fa1/15
1002 fddi-default active
1 enet 100001 1500 - - - - - 1002 1003
5 enet 100005 1500 - - - - - 0 0
6 enet 100006 1500 - - - - - 0 0
1002 fddi 101002 1500 - - - - - 1 1003
sh int fa1/2
FastEthernet1/2 is down, line protocol is down
Hardware is Fast Ethernet, address is 0017.59bd.af3a (bia 0017.59bd.af3a)
reliability 195/255, txload 1/255, rxload 1/255
Keepalive set (10 sec)
Received 25134 broadcasts, 0 runts, 0 giants, 0 throttles
3146495 input errors, 1271941 CRC,
0 output errors, 0 collisions, 2 interface resets
0 lost carrier, 0 no carrier
copchgasr4#sh int fa1/3
FastEthernet1/3 is up, line protocol is down
Hardware is Fast Ethernet, address is 0017.59bd.af3b (bia 0017.59bd.af3b)
Description: Connection to MDS I-NET 900 AP Radio 172.29.12.100
Auto-duplex, Auto-speed
Last input never, output never, output hang never
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
706 packets output, 57186 bytes, 0 underruns
copchgasr4#sh int fa1/4
FastEthernet1/4 is up, line protocol is down
Hardware is Fast Ethernet, address is buffer
what does this mean?????
glen.grant Tue, 09/02/2008 - 10:40
  • Purple, 4500 points or more
It means none of the ports that are in vlan 6 are in a connect status so the SVI will be in a up/down state. Once a device in that vlan comes active the SVI will go up/up.
mahesh18 Tue, 09/02/2008 - 10:47
thanks for reply
i see one inetrface fa1/2 is up /up now
sh int status
Port Name Status Vlan Duplex Speed Type
Fa1/0 20Mb Canopy Ethern notconnect routed full 100 10/100BaseTX
Fa1/1 Connection to MDS connected 5 a-half a-10 10/100BaseTX
Fa1/2 connected 6 a-full a-100 10/100BaseTX
Fa1/3 Connection to MDS notconnect 6 auto auto 10/100BaseTX
Fa1/4 notconnect 6 auto auto 10/100BaseTX
Fa1/5 notconnect 6 auto auto 10/100BaseTX
Fa1/6 notconnect 6 auto auto 10/100BaseTX
Fa1/7 notconnect 6 auto auto 10/100BaseTX
Fa1/8 notconnect 6 auto auto 10/100BaseTX
Fa1/9 notconnect 6 auto auto 10/100BaseTX
Fa1/10 notconnect 6 auto auto 10/100BaseTX
Fa1/11 notconnect 6 auto auto 10/100BaseTX
Fa1/12 notconnect 6 auto auto 10/100BaseTX
Fa1/13 notconnect 6 auto auto 10/100BaseTX
Fa1/14 notconnect 6 auto auto 10/100BaseTX
Fa1/15 notconnect 6 auto auto 10/100BaseTX
sh int vlan6
Vlan6 is up, line protocol is up
Last input 00:00:30, output never, output hang never
3553080 packets input, 356611237 bytes, 0 no buffer
Received 10756 broadcasts, 0 runts, 0 giants, 0 throttles
4417667 packets output, 297040654 bytes, 0 underruns
copchgasr4#
many thanks
